That makes sense...I appreciate the detailed answer. So if the base resistors and POT and wired in parallel, then ultimately it's the POT that dials in the turning off/on of the transistors correct? So if you went with 220, 470, or 680...with a 1K POT you could dial in the same overall resistance for all of them and achieve the same transistor behavior, right? Or is this wrong?
Is this is wrong, there must be something happening before the master resistor in the circuit...
Originally posted by Tom C
