Hello! I am currently charging 3 batteries at the same time with my SG device (5 filar; 1 trigger + 4 transistors 150 feet of 18 gauge litzed).
I remember seeing in the Energy from the Vacuum series that Tom Bearden and I think also JB said that the radiant energy did not care how many batteries were hooked up, or something like or I could be wrong about this.
Anyhow, For the last month I had the batteries hooked up in parallel, this way the voltage is the same for all of them. I saw somewhere maybe on this forum that you could also connect them in series. So I did it. Now each battery seem to take the radiant energy accordingly to its own capability. The voltage for each battery is between 12.8 and 14 volts. None shows the same voltage. The voltage at the SG Charging side reads about 40+ volts. The SG does not seem to mind.
Does anyone is doing this or have suggestions?
