First Bedini build - it runs but it’s HOT!
Hi Guys, I'm new to this forum and I've joined up in the hope of connecting with other like-minded people and to hopefully overcome issues that I encounter as I build more of these devices and hopefully improve, innovate and share some of my own ideas.
Have been studying the Bedini monopole for some time and bought the beginners handbook as I was having a few problems with my first attempt and hoped it might shed some light on troubleshooting.
I've got it running, (please see pictures,) however when I removed the charging battery to see the radiant flash in the neon bulb, the 100 ohm resister burnt out after a few minutes . I tried several other resistors of increased capacity up to 300 ohms however all I eventually did was to make the transistor get very hot.
Tried magnets at various heights above coil and different potentiometer positions however it still burns out the resistor over time. When it runs with the charging battery connected it doesn’t burn out but still gets very hot.
Used correct components however I was a little naughty and used small ½ inch square by ¼” deep neo’s instead of strontium ferrite – (however I’ve increased the gap between the coil and wheels,) and the magnets are quite small so I thought it would still run OK.
Any ideas on why the resistor and transistor are getting so hot and what I can do to improve things would be appreciated.
