Hi all!
Well i successfully completed 20 runs!
My last discharge procedure show interesting result:
after discharging battery to 10 volts , the battery idle and during idle the voltage increased to 12,01 V!
This "strange" behavior did not happed before! I post my runs-experiments data in excel file (see attachment)
My next goal is building battery swapper and customized solar panel , well the second thing probably will happen sooner.
Well and i will further continue to charge and discharge my battery, because i want to get max result, like Bedini explained the battery can take a lot more that battery manufacture tell us!
Some hints to newcomers:
yes it's possible to charge sealed lead acid battery with Bedini SSG.
yes it's take a lot of time to charge it properly.
For discharge use only fix resistors and do not discharge below 11Volts, in my case i have done to 10V but it was only after battery showed some voltage increase.
20Runs-experiments.zip
