For mail coil, different connection will give either attraction mode or repulsion mode. How about trigger coil? Is there any difference if I connect it in different direction?
Freeenergy, the machine will only run with the trigger coil connected correctly. If it doesn't run you know you have it backwards.
I wired the 8 fillar coil (7 wires are #20 and one trigger wire #23) using attraction mode (connect battery positive terminal to #20 top wire of coil). Can i said that the #23 trigger wire on the top of coil should connect to resistor and #23 trigger wire at bottom of coil should connect to emitter of transistor?
