OK Tom, I hear what you’re saying about “building a multi strand single coil unit using mjl transistors,” and I will do that as soon as I’ve finished building my 4th Bedini as I’m currently experimenting with maglev bearings.
In this third build I’ve incorporated several improvements from all the research I’ve done and was delighted to reach 1354 RPM on only 270 milliamp current draw using a standard bifilar coil. I’ve since upgraded it to maglev and increased RPM to 1395 however it’s running on a bolt with 10 thou clearance; so when the ground shaft arrives I should get more RPM for the same current.
https://groups.thrivemovement.com/th...a-energy-group
