Hi everybody,
thanks for the many helpful posts in this kindly forum. This is my first post. I've been in this radiant energy stuff for approx. 2 month now, so I don't understand most of things that are going on in these really strange behaving devices. At the moment I'm just conditioning my batteries, and built a wheel sg and a solid state version with the CPD-Mod from Patrick. I'm from germany, so please excuse my bad english.
First I ran my ss ssg with 0.9 Amps and the transistors were getting very hot, so I inserted an additional trigger base resistor (180 ohms). Now the device runs at 0.54 amps and the transistors are just a little bit over roomtemperature. The coil doesn't heat up. I thought ok, that's seems to be a normal behaviour.
But:
Can someone explain to me why this resistor is getting cold, and I mean realy cold? It is not freezing, but the temperature is way under roomtemperature. And if it's getting cold, is it a good or bad sign?
The first thing, that crossed my brain was that it is a kind of peltier effect
Thanks again.
gobe
But:
Thanks again.
gobe
