I just hope we all understand that one does not count for the many that support. thank you for this site to help us get things right. I can see from out here in the woods that John k. and Tom C. have obviously been a great help among others.
So in the spirit of moving forward, I am grateful for the information on the SS Tube and for getting to make a replication. Although I have never liked any of the SS stuff before and had very bad experiences with it.
I see that the coil has an amount of energy to transfer and that it can divide this energy to multiple batteries based on differences of impedance. In my testing so far the gap between two similar batteries at different states of potential is closing the gap fast. I see this as one very practical device.The practical application of this becomes quickly obvious.
I don't understand Lameller currents very well, but here is how I see what is going on. The coil has a fixed energy potential. That energy follows the path of least resistance as it exits the coil. So as a battery builds up an impedance the less impedance takes more of the energy. For example if I had 12 watts in the coil and two balanced batteries then 6 watts would go to each battery. But if the impedance is mismatched then say 4 watts to one battery and 8 to the other.
Outback inverters came out with a balanced inverter system about 10 years ago. It was designed so that if you had two 2000watt inverters you could put one inverter on one leg, and the other inverter on the other. This was a common practice and Trace and others had a wire you would attach between them to keep in phase. But what was unique about the outback is that the inverters would put and could put all 4000 potential watts on one leg based on the demand. Not an easy thing to do. I see this as very similar.
The thing that is so mind blowing about this SS unit and being able to do this with the SSG is that is it's done with apparent simplicity. My complements, adulations, and general thanks!
So I have two questions I would like to have confirmed so I can move forward.
1- I understood that with this method you would need a trigger strand for each power strand, is that true for the SS and the rotored SSG?
2- Does the SS version have the same qualities as the SSG in that you cannot swap batteries?
Clarification on these two points would be extremely beneficial.
Les
Les
