Hi Aaron, I left the 17 AH battery on all day and at 4:30 pm the battery was hot (approx. 100-105deg F) and the voltage was at 14.1. I took it off and let it cool down. I also tried two small 5-7 AH? 3X5X5 lead acid wet cell 12 volt batteries and they each peaked out at 16.15- 16.20 volts after about 10 minutes each while on charge. My take is someone mistook a 16 for a 15 while in the burn in mode. At least it does stop although it is sort of high. On the good side it will handle quite a large battery and will also make sure there is no sulphates left over on the plates. Just have to watch the water levels.
Bud
Bud
