2A12 Battery Charger
2 Amps, 12 Volts
2 Amps, 12 Volts
Considered a "trickle charger" by most standards, the 2A12 is more like a "little GIANT" of a charger.
This charger is designed as an automobile battery topper, with its remarkable ability to break through battery sulfation. The 2A12 delivers a slow, but remarkably powerful and revitalizing charge. Can easily restore a vehicles cranking power to start the engine.
Simple, compact, and portable charging power for 12 Volt batteries. Universal power supply plugs into any AC system, world-wide, from 100 VAC up to 220 VAC. Can also charge all other small to medium 12 Volt battery systems.
- Universal portable power supply accepts 110-240VAC input.
- Easy-to-read LED status displays state of charge.
- Lightweight and very portable.
- See owner’s manual for more details.
- Physical - 3.25"W x 2.75"H x 4.5"D (excluding external power supply)
Approx. 2 lbs.
- *1 Year Warranty
GET YOUR 2A12 HERE: ENERGENX 2A12
