24A12
Battery Charger
24 Amps @ 12 Volts
Battery Charger
24 Amps @ 12 Volts
This industrial charger charges and restores the capacity of medium to large 12 Volt Lead-Acid batteries.
This work horse can rapidly break down layers of sulfation and restore the battery's capacity.
We recommend that you use the 12V Battery Load Box to cycle the batteries for full rejuvenation.
This rapid restoration of capacity is what we call Rejuvenation. There is no other battery charging system in the world that can do this!
- 12V model is available for use with 110VAC 60Hz or 240VAC 50Hz.
- See owner’s manual for more details.
- Unit weighs: 39 lbs, 2 oz.
- Physical shipping box size is: 18 x 15 x 13
