12V BATTERY LOAD BOX
This is an automatic battery discharging system that allows you to discharge 12V battery banks of various sizes or capacities at different rates.
It has four buttons that allow for four different loads ranging from 3 Amp to 50 Amps, or any combination of these four load settings.
The Battery Load Box will discharge batteries to approximately 10.5 volts before it stops discharging the batteries.
It comes with instructions, meter and software for logging capabilities to determine battery capacity. Requires USB to Serial cable that is easily found at Radio Shack or online.
For serious rejuvenation of batteries, after you charge them with one of our other chargers, connect this to draw them down then charge them back up. Over multiple cycles, you will see the battery capacity continue to grow!
- See owner’s manual for more details.
- Unit weighs: 19 lbs, 7 oz.
- Physical shipping box size is: 18 x 15 x 13
- *1 Year Warranty
GET YOUR OWN ENERGENX INDUSTRIAL 12V BATTERY LOAD BOX: ENERGENX 12V LOAD BOX
