wide coils
  • wide coils
ID:	51418[ I am wondering if the window motor would work with this coil?
    Originally posted by aetherman View Post
    [ATTACH=CONFIG]6653[/ATTACH][ I am wondering if the window motor would work with this coil?
    Hey,
    Where do you want the rotor to rotate?? best is have a square frame jig to make the windings and then slip it out once you tighten the truns with a multiple cable ties..this is how i do it.
ID:	49703 Here is the rotor. It goes inside the coil.
        [ATTACH=CONFIG]6659[/ATTACH] Here is the rotor. It goes inside the coil.
        Hey,
        I feel the Magnets are suitable for Newman Motor rather than for the Window motor..
        The extended Null point(Bloch wall) of the Magnets make it more a 'SPIN MOTOR' than a 'ROTATION MOTOR' like wise the Switching is different in each case.
          I don't have any neos so I just put the Newman type rotor inside the wide coilClick image for larger version
            This motor runs really well but needs the Bedini-Cole circuit for more torque. Click image for larger version
              The Bedini- cole switcher noticeably increased rpm.Click image for larger version
                https://www.youtube.com/watch?v=671Vf3PFlWU&t=115s I wonder if these motors are window motors.
