Hi to all,
I posted two years ago somewhere in this forum. I got the FEG book and intended to build a window motor. The one with the ball rotor (page 29, 2nd edition).
So now I have built my first model. For study, of course. Not such a masterpiece like the original one but it works.
The secondary coil is the generator coil. It gives enough electrical impulse to light a 3.3V LED AC wise. This is done by induction caused by the spinning ball rotor.
The rotor is driven by a standard SG circuit, or other circuitry shown in the book, like the bipolar switching circuit shown on page 20.
I made the trigger/power coil with 28/26 awg wire and the generator coil with 26 awg wire, each 1 lb in weight.
Its a small toy motor, good enough for study.
I let it spin using SG switching and trigger/power coil. When it runs I take the signal generated from induction of the spinning rotor as a trigger signal to run for example a larger coil like Ron Pough made them with BD 243 transistor switching. 5 coils wound on one spool.
With that arrangement I can charge my 8.4 Ah lead acid battery in a way that I am totally convinced this is done by radiant energy.
I also like to light up mains power LED lamps on such a generator - in a bucket filled with tap water. This is fun!
Of course it came to my mind to make a solid state device with 555 timer using that coil or more of them.
So I put together the circuitry given later in that book, on page 99 for example, called Inverted Potential Switch.
I put it together but the transistors are not switching. The potential storage capacitor charges up of course but there is no switching in the 2N3440 and MJ15024.
Also, there is nothing said about what to do with that circuit, although I can imagine of course. The primary input battery 9 V is for running the circuit.
The input is for both ends of wire coming from a generator coil. The 12 V battery is load, for charging.
Can anybody on this forum help me with that particular circuit. Are there any references or threads referring to it?
I am stunned about not finding much about the FEG book in google search. Especially practical things, like people who have built the circuits.
What I need is a solid state switching device that works, with battery switching.
If you are interested in the window motor I have built, please let me know then I can expand a little bit posting pictures and so on.
Best regards to all,
Elmar
Elmar
