I know there are already a couple of other threads on this, but decided to start a new one to discuss my 17 year old grandson's (Daniel) replication of Veljko Milkovic’s 2-stage mechanical oscillator (with a little help from grandpa). I gave him an old, small, girls bicycle which he cleaned up and painted. Then I helped him machine an adapter sleeve for two ball bearings to replace the pedal crank for the pivot point. He took all this home and constructed a nice wooden A-frame for a base and installed the bicycle frame in the base with a 5/8" rod through the pivot bearings and wooden A-frame.
Next I helped him machine a stainless steel piece for a pendulum and an aluminum piece for a ball bearing pendulum pivot. These were attached together with some ready rod and then bolted into place at the rear wheel attachment location of the bicycle frame. He then added two upright supports for beam travel stops on the work (long) end of the bicycle frame near the front fork tube. And we added a small spring to assist the downward movement of the work end.
I had an old, small SSG coil and single transistor circuit laying around, so we mounted these under the pendulum to which we added a ceramic magnet. We have it working and pounding away at the stops on the long end. But we need a little stronger coil and circuit to get full swing of the pendulum for maximum effect. So we wound a new coil with one trigger, two power, and one isolated recovery winding. Next week we will build a new, better SSG circuit with the recovery going back to the run battery for reduced primary current draw as shown by Aaron.
The plan is to use the mechanical output to drive a flux gate generator for useful electrical output.
