Now that we have arrived at a logical conclusion as to what Teslan Energy is serengtiplains I would like your, and others opinion as to what the standard vanilla schoolgirl motor is doing while operating in the active medium? Remember that in operation the SG is charging with a negative charge.
What Is Teslan Energy?
Originally posted by longhorn View PostNow that we have arrived at a logical conclusion as to what Teslan Energy is serengtiplains I would like your, and others opinion as to what the standard vanilla schoolgirl motor is doing while operating in the active medium? Remember that in operation the SG is charging with a negative charge.
Schematic for Parametric oscillator/ LC circuit with energy sink
Introduction
The Earth's Electrostatic Charge
Tesla's intent was to condense the energy trapped between the earth and its upper atmosphere and to transform it into an electric current. He pictured the sun as an immense ball of electricity, positively charged with a potential of some 200 billion volts. The earth, on the other hand, is charged with negative electricity. The tremendous electrical force between these two bodies constituted, at least in part, what he called cosmic energy. It varied from night to day and from season to season but it is always present.
The positive particles are stopped at the ionosphere and between it and the negative charges in the ground, a distance of 60 miles, there is a large difference of voltage - something on the order of 360,000 volts. With the gases of the atmosphere acting as an insulator between these two opposite stores of electrical charges, the region between the ground and the edge of space traps a great deal of energy. Despite the large size of the planet, it is electrically like a capacitor which keeps positive and negative charges apart by using the air as a non-conducting material as an insulator.
The earth has a charge of 96,500 coulombs. With a potential of 360,000 volts, the earth constitutes a capacitor of .25 farads (farads = coulombs/volts). If the formula for calculating the energy stored in a capacitor (E =1/2CV2) is applied to the earth, it turns out that the ambient medium contains 1.6 x 1011 joules or 4.5 megawatt-hours of electrical energy.
In order to utilize this high-voltage energy you must do two things -- make an energy sink and then devise a way of making the "sink" oscillate.
(Bedini Schoolgirl Motor)
SOURCE: http://johnbedini.net/john34/Impulsetec.jpg
Definitions
Energy Sink- a molecule or a group in a molecule that is able easily to accept energy transferred to it from another component of the system. (In example: a lead acid battery.)
Parametric oscillator- A parametric oscillator is a harmonic oscillator whose parameters oscillate in time.
LC circuit- The purpose of an LC circuit is usually to oscillate with minimal damping, so the resistance is made as low as possible.
Ok, slightly different direction here. So charge accumulates. In a Tesla coil, the primary is open circuit until discharge, which means on each cycling of the power supply, charge accumulates in the capacitor which, at some threshold voltage, discharges across the spark gap. That discharge, being almost a short, creates an *enormous* current (infinite for zero resistance) across the primary of the transformer whose secondary is itself a magnifying open-circuit charge accumulator. Then per Townsend Brown, because electrogravitic effects, for instance, increase exponentially with charge, charge accumulation in an open circuit reveals itself as the secret to gravitic/light effects of any (including a Teslan) open-circuit device.
At threshold voltages, new matter can and will appear, and existing matter can be transmuted into more complex (heavier) forms. Charge accumulation is therefore evidently the source of earth growth. These charge accumulations discharge through electrical (lightning) and magnetic (volcano) discharges. In a circumstance of discharge, NO GROWTH.
Radiant energy attracted to an energized circuit at the moment circuit is switched
Originally posted by serengetiplains View PostOk, slightly different direction here. So charge accumulates. In a Tesla coil, the primary is open circuit until discharge, which means on each cycling of the power supply, charge accumulates in the capacitor which, at some threshold voltage, discharges across the spark gap. That discharge, being almost a short, creates an *enormous* current (infinite for zero resistance) across the primary of the transformer whose secondary is itself a magnifying open-circuit charge accumulator. Then per Townsend Brown, because electrogravitic effects, for instance, increase exponentially with charge, charge accumulation in an open circuit reveals itself as the secret to gravitic/light effects of any (including a Teslan) open-circuit device.
Radiant energy is attracted to an energized circuit only upon switching.
This is the reason that in building a shuttling circuit to manage radiant energy a BJT makes a good choice as not only a switch but also a collector because in operation a BJT involves both electrons and holes. The BJT acts as a collector for the high frequency electrons collected by its holes filling it up then upon switching releases the electrons to the downstream circuit.
Originally posted by longhorn View PostBuildup of radiant energy charge is depended upon high frequency oscillations from the collector source that upon switching is then collected by the capacitor.
Through successive experimental arrangements, Tesla discovered several facts concerning the production of his effect. First, the cause was undoubtedly found in the abruptness of charging. It was in the switch closure, the very instant of "closure and break", which thrust the effect out into space. The effect was definitely related to time, IMPULSE time. Second, Tesla found that it was imperative that the charging process occurred in a single impulse. No reversal of current was permissible, else the effect would not manifest. In this, Tesla made succinct remarks describing the role of capacity in the spark-radiative circuit. He found that the effect was powerfully strengthened by placing a capacitor between the disrupter and the dynamo. While providing a tremendous power to the effect, the dielectric of the capacitor also served to protect the dynamo windings. Not yet sure of the process at work in this phenomenon, Tesla sought the empirical understanding required for its amplification and utilization. He had already realized the significance of this unexpected effect. The idea of bringing this strange and wondrous new phenomenon to its full potential already suggested drilling new possibilities in his mind. He completely abandoned research and development of alternating current systems after this event intimating that a new technology was about to unfold.
"WE do not need to do this with high voltage as it works on any level."
The effect could also be greatly intensified to new and more powerful levels by raising the voltage, quickening the switch "make-break" rate, and shortening the actual time of switch closure. Thus far, Tesla employed rotating contact switches to produce his unidirectional impulses. When these mechanical impulse systems failed to achieve the greatest possible effects, Tesla sought a more "automatic" and powerful means. He found this "automatic switch" in special electrical arc dischargers (air gap switching). The high voltage output of a DC generator was applied to twin conductors through his new arc mechanism, a very powerful permanent magnet sitting crosswise to the discharge path. The discharge arc was automatically and continually "blown out" by this magnetic field.
Imperative toward obtaining the desired rare effect, the capacitor and its connected wire lines had to be so chosen as to receive and discharge the acquired electrostatic charge in unidirectional staccato fashion. The true Tesla circuit very much resembles a pulse jet, where no back pressure ever stops the onrushing flow. Electrostatic charge rises to a maximum, and is discharged much more quickly. The constant application of high voltage dynamo pressure to the circuit insures that continual successions of "charge-rapid discharge' are obtained. It is then and only then that the Tesla Effect is observed. Pulses literally flow through the apparatus from the dynamo. The capacitor, disrupter, and its attached wire lines, behave as the flutter valve.
Originally posted by longhorn View PostEverything Tesla said works too with low voltage batteries, providing the switching is correct.
Original Source: This article is excerpted from John Bedini's website at http://johnbedini.net/john34/bedinibearden.html
I read these quotes and have read the original books from which they're taken. Let's look at the operation of a simple Tesla coil. I'll tell you what I see. In a Tesla coil, the power supply charges a capacitor, which at a threshold voltage then discharges across the spark gap. If you were to meter the current crossing that gap, you would see an initial very fast current rise followed by a slowly moderating decline of that positive value because of resistances and stray inductance in the circuit, and given the discharge slope of the capacitor. Am I right in this?
If I am, the current waveform plotted over time would be asymmetrical ~~ a steep rise followed by a less steep fall. That current waveform then goes through the primary of the transformer, which creates a voltage waveform in the secondary tracking the shape of the current waveform in the primary. This voltage waveform is essentially an asymmetrical AC wave.
It appears to me that asymmetrical voltage rise-time/fall-time is therefore effective factor giving rise to so-called radiant energy. This appears to correspond to Tesla's original observation of blue light upon throwing the switch on a DC circuit. That light, I think, appeared because the voltage rise upon throwing the switch was steeper than the voltage fall following.
Townsend Brown's initial observation that electrogravitics effects occurred before a capacitor could fully polarize seems relevantly on point with this. In essence, it appears that asymmetrical acceleration/deceleration gives rise to all these effects under what seems the operating principle that space bends disproportionately the faster the voltage rise, exponentially.
Originally posted by serengetiplains View PostI read these quotes and have read the original books from which they're taken. Let's look at the operation of a simple Tesla coil. I'll tell you what I see. In a Tesla coil, the power supply charges a capacitor, which at a threshold voltage then discharges across the spark gap. If you were to meter the current crossing that gap, you would see an initial very fast current rise followed by a slowly moderating decline of that positive value because of resistances and stray inductance in the circuit, and given the discharge slope of the capacitor. Am I right in this?
It appears to me that asymmetrical voltage rise-time/fall-time is therefore effective factor giving rise to so-called radiant energy. This appears to correspond to Tesla's original observation of blue light upon throwing the switch That light, I think, appeared because the voltage rise upon throwing the switch was steeper than the voltage fall following.on a DC circuit.
You stated; "If I am, the current waveform plotted over time would be asymmetrical ~~ a steep rise followed by a less steep fall. That current waveform then goes through the primary of the transformer, which creates a voltage waveform in the secondary tracking the shape of the current waveform in the primary. This voltage waveform is essentially an asymmetrical AC wave." yes you are correct the waveform seen 'is' an asymmetrical AC wave. This is what is powering our electrical grid at present, We have been utilizing radiant energy in our current power generation systems calling it AC since Tesla discovered AC through rotating magnet fields also called poly phase, we do not generate power at a generation plant, we attract it, the actual energy you and the rest of us are utilizing right now is radiant or dark energy from photons.
A photon is an elementary particle, the quantum of light and all other forms of electromagnetic radiation, and the force carrier for the electromagnetic force, even when static via virtual photons. The effects of this force are easily observable at both the microscopic and macroscopic level, because the photon has zero rest mass; this allows long distance interactions. Like all elementary particles, photons are currently best explained by quantum mechanics and exhibit wave–particle duality, exhibiting properties of both waves and particles. For example, a single photon may be refracted by a lens or exhibit wave interference with itself, but also act as a particle giving a definite result when its position is measured.
http://en.wikipedia.org/wiki/Photon
Originally posted by serengetiplains View PostBearden goes further to say that trapped translation EM energy, as a scalar potential, is "nominally composed of spin-2 gravitons" which are themselves composed of photon-antiphoton (+EM and –EM) pairs. Light and gravity, in other words, become at the level of Teslan interiority, the external show of what EM actually in its interior-exterior is.
So if the Tesla effect depends upon magnitude of voltage acceleration, is that effect perhaps relativistic or relativistic-like? It would seem that charge-acceleration affects that thing called time, which is none other than space of course, such that we have, in effect, a compressing or expanding (a bending) of space. Or call it time.
Originally posted by serengetiplains View PostSo if the Tesla effect depends upon magnitude of voltage acceleration, is that effect perhaps relativistic or relativistic-like? It would seem that charge-acceleration affects that thing called time, which is none other than space of course, such that we have, in effect, a compressing or expanding (a bending) of space. Or call it time.
One may wish for many things, but on the same token should be careful what they wish for!
To admit that anyone of us here on terra firma can manipulate space/time with the flip of a switch is to admit the controlling tyrant within each of us, biased towards an individual's particular bias on any particular day. One day it may be purple trousers worn with a paisley shirt or the next with pink truffles and lavender skivvies, the suggested ability to manipulate one's environment and others; is beyond comprehension - godlike.
What is our fetish with bending space/time?
The most reasonable assumption from the premise is given to us in the quest is in the definement of the graviton. The graviton in the colloquial is descriptive of the concerns raised here.
Graviton
Unlike the force carriers of the other forces, gravitation plays a special role in general relativity in defining the spacetime in which events take place. In some descriptions, matter modifies the 'shape' of spacetime itself, and gravity is a result of this shape, an idea which at first glance may appear hard to match with the idea of a force acting between particles.Because the diffeomorphism invariance of the theory does not allow any particular space-time background to be singled out as the "true" space-time background, general relativity is said to be background independent In contrast, the Standard Model is not background independent, with Minkowski space enjoying a special status as the fixed background space-time. A theory of quantum gravity is needed in order to reconcile these differences. Whether this theory should be background independent is an open question. The answer to this question will determine our understanding of what specific role gravitation plays in the fate of the universe.
Wikipedia: http://en.wikipedia.org/wiki/Graviton (Comparison with other forces)
So as General Relativity appears is "back ground independent," the Standard Model when contrasted is highly regimented because it is not back ground independent which is more at public policy based upon the political will in relationship to guaranteed constitutional rights. It is the Standard Model which goes begging as it is undefined bending of reality to the will of the despot. You may ask what is the meaning of this diatribe, but it may be equally ask what is the infatuation in bending (manipulate) time/space based upon a Standard Model?
No I do not assume that all the premise of General Relativity is correct, but I do appreciate it's spirit of independence.
The end sought by free energy advocates is freedom from the elitist Standard Model of centralized control of the local time/space domain, which is in the spirit of Teslan Energy Systems.
