Water Spark To Hydrogen And Water Vapor Pressure Ran Engines 2005-2008
  • russwr
    Waste Spark Removal Briggs Mower Engine For Hydrogen Conversions
    I completed building the circuit for eliminating waste spark. It's the plug in bread board type, not soldered. It's easier to make adjustments later. Two photos for you today-- did not go through. I have handful of different magnet Hall sensors to try out and see which one should be used on engine with NORTH pole. Some of them are industrial with cables. Three wire type as +Vcc , grnd, and signal out. Most Halls are used for South pole reception. You have to bend over the Hall for the rear side use, or reverse, and mount with bracket. I will use hand movable magnet north pole only for first tests. Then to switch over to my revolving wooden bench flywheel with magnet , Magnetron, and spark plug. First yellow Led is first state (Fire) , the red Led is 2nd state with relay switch on that shorts ignition to ground BEFORE magnet reaches T.D.C. Then next passing point is reset back to first state fire. The other guy on Youtube who built his soldered type circuit years ago has my same name Russell. His board is similar to mine - not copied. I designed it myself. Plastic board put in miniature vise with strong lamp and use needle nose pliers. With 9v battery use, I design small circuits with 2 ma type, .002A led's. Most Led's are 20ma .020A. The battery lasts longer, but those are expensive and are special order. You just change the resistors. Of course, 2 batteries can be put in parallel for more time. Yes, I'm still working on the S1R9A9M9 system. 'Questions?
  • russwr
    I put together another handmade S1R9A9M9 electromagnet for use with Four amps current. My last other one was for 6 amps with different windings. The now current one is exactly like the original as per unusual winding method and like Megatran, with same original count of turns. Red white and blue just like our flag. It has variable inductance with pull core. Another one of my improvements. Nathren said a set up needed about 15 amps total. That would include the "smaller" Inverter input 11 Amps + 4 Amps electromagnet. Ohms law step up transformer voltage ratio 1:10 as same as increase of input side power current. This was assuming the dual alternators type was not changed on his 18HP Briggs. He told me directly that his engine DIDN"T HAVE AN ALTERNATOR! All riding lawnmower engines have an alternator. He said he bought it new just for the 2008 videos to make. I saw lots of grime, dirt/dust on it in close up photos from years of use. The dual alternators type with red + black wires with bridge rectifier added to both sides produces about 15 volts DC at about 15 amps max capability. PEAK current on bench oscilloscope set circuit as 7 amps, with proper resistance in series, with AVERAGE current over full cycle time as about 1.3amps at low duty cycle. See photo electromagnet.
    Later today, I also mounted a new starter motor on project Briggs 12HP engine. It was electrically insulated from engine block with plastic bolts and plastic washers. The battery ground cable mounted onto starter only. Separate needed connections will go on 2 mounted brass bus strips for plus and minus of battery wires power as needed. The Inverter box secondary side firing to spark plug will never burn out as shorted to battery through spark plug ground, as per many other people's previous disasters. The flywheel has proper MATCHING aluminum ring gear, along with proper MATCHING PLASTIC starter motor small gear. Plastic gear during contact cannot make any electrical connection. Verified with ohmmeter. I'm always pushing forward.
    I am also putting together P.W.M. so as can vary the output of Inverter final DC and KEEPING PEAK VOLTAGE THE SAME, while varying the current , wattage, and duty cycle on time. The 100 volts is necessary for the tiny electrodes of zero ohms spark plug. I didn't want to get into capacitor discharges , since they go in the realm of microseconds, not required milliseconds of spark plug.
    Sometime I will rewrite my poor drawings schematic diagram and send copy, so as you can see my judgments for final circuit. It includes many diodes and 2 Dayton brand modified Inductors for 1.75millihenries. I also have for later tests, the 2 vacuum chambers hand made of magnets, spark gap, diodes and inductors.
  • russwr
    I'm changing my methodology of hook up to my 12HP mower engine. Instead of designing for full 20A alternator output to run the conversion circuit, I am changing over to bench "power source"
    to run main circuit with the under the wooded bench engine vertical shaft for car 52A alternator , belts and pulley, to recharge 12v mower battery. This method fully allows no shorting-
    electrical problem of Inverter box ground and battery ground. This is what hindered many people before, and I want a better chance of instant running of water engine when 1st started.
    Project has taken too long.
    Return line to Inverter hooks to wire and spring steel retainer clip on bottom of spark plug , just like from Georgia engines converted. One ohm power resistor in line for use with
    oscilloscope to monitor and adjust current flow.The way to do this is with smaller Briggs engine that has flywheel with ALUMINUM ring gear. The matching starter motor will have PLASTIC
    16tooth small gear. Starter is mounted with 2 black nylon plastic 8MM bolts 12mmm long with 2 plastic nylon washers. This insulates starter from engine block fully, when Inverter is
    activated. Slight distance change inbetween the 2 gears. Ground cable attaches to starter housing.
    Method is had by changing old armature Magnetron to the most modern Magnetron with dual cables, modern universal built in trigger , not Briggs type, so that Magnetron is NOT an
    autotransformer. (Separate secondary side) The ignition process is self contained without using BATTERY ground, as power is from one magnet on outside of flywheel.
    Main power source is PURE SINE WAVE ONLY Inverter similar to Lvyuan 500W Blue box with MORE available SURGE currents, to get 7amp pulses through spark plug. The most common modified sine
    wave type boxes do not give much higher surge current. Bridge rectifier and filter capacitor gives proper DC output.
    What I'm talking about is the instants when the battery ground is normally at bottom of spark plug, and Inverter power jumps gap and connects with ground within the 0 to 34 degrees ignition
    ON TIME, and repeated. This is also why a common boost converter or regular bench power supply can't be used. Inverter only with separate secondary side, they come in high frequency and
    also 60 cycles.The 2008 2 videos had the dangerous negative high voltage on the car battery during the starting mode.
    The S1R9A9M9 electromagnet allows high volts to go straight through without problem with the 12vDC line. I use 10KV white china cable to stop all shorts along with #16 gauge solid insulated
    wire for the 12 + 23 turns, with adjustable pull core for magnetic field inside vinyl tube center. The series adjustable power resistor allows change in input 6A battery current for the
    field adjustment. This will change the pulse on time of high voltage so as more contact time of Inverter current with the water solution.
    Photo included today is gadget for testing firing of hydrogen by popping off end PCV cap as press fit. Baking soda/water solution put on plug terminals . The outer ground lug is cut off for
    wide gap, and allowing blast to go straight out. Stainless steel marine spark plug is sealed in with epoxy at one end. Ignition white cable return line is screwed to plug base through
    plastic shell.
  • russwr
    2008 Mower engine ran on salt water.
    Closing in on the final conversion electrical circuit as used during the successful demonstrations 18HP Briggs on YouTube. The hand wired S1R9A9M9 electromagnet on 10amps provided magnetic field to spark plug gap and OVER the plug wire to readjust the engine timing to late timing ATDC. The duty cycle of on time was for the current pulse through spark plug of needed 7amps PEAK.
    There was a separate Inverter box of about 300watts that provided the current at 110v DC to fire plug. Use was about only 150 watts, due to the low duty cycle. Average value of current on hand meter would be about 2 amps, for the 10amps peak. The box was hidden in rear hole of cement block with engine shaft. (plenty of clearance.) Other parts hidden in sealed plastic tub on side of engine.
    The car battery operated starter motor and also the electrical conversion circuit. Battery removed. The modified Briggs alternator with flywheel with the larger type magnets would provide max 20amps as divided between the electromagnet and inverter box primary side. Engine then ran fully on alternator permanent magnets at idle RPM . Can use black + black wires stator or yellow + yellow stator as are both Exact same construction. Hydrogen gas evolved and fired with also water vapor pressure that runs the piston. See S1R9A9M9 videos 1 + 2. Questions?
  • russwr
    There are options when selecting a replacement ignition coil (Magnetron) for the mower engine. I was interested in changing over to positive high voltage rather than normal negative high voltage. There are a couple reasons. When tinkering with small engine for alternate uses/ fuels, There are high voltage shocks received when connecting parts such as resistor, capacitor, L coil, to engine ground. The spark plug refuses to fire, and bypasses to go up another line such as parts. During that time we get shocks from the engine. Also, when using the original old style Magneto as just a plain transformer before 1982, you can put it upside down on engine bracket and get positive high volts, but at away reduced level. You don't get up to 15kv anymore. The Autotransformers normally have the primary coil hooked directly with secondary side. The full secondary is normally primary + secondary in a negative "mode" Less wire is used in the positive mode.
    Now then, there actually is a better way to get positive type high voltage at FULL VALUE VOLTS! If your Briggs engine is a one cylinder type, you can purchase a modern replacement Magnetron with DOUBLE CABLES. The secondary side is not connected with primary. When used on the twin cylinder engines, each spark plug gets different type power. Negative on one side and positive on other cylinder. Also, if you get the most modern type dual cables Magnetron, it will have the better type built in UNIVERSAL type trigger , rather than the Briggs brand trigger. Engine will fire at a lower RPM of flywheel , just like in the "olden days". Just hook the negative cable to ground and the positive cable to spark plug. Compare the photos of armature Magnetrons on Ebay to see the difference.
  • russwr
    It's my current assumption that the conversion circuit of S1R9A9M9 2008 lawn mower water engine 18HP on You tube videos, had used a hidden "small dimension size" Inverter box, about 300-500watts , that was INSIDE the rear hole of cement block with engine on top . Plenty of clearance also for the vertical rotating crankshaft. The other parts were hidden in sealed, painted plastic tub , hanging on side of engine. we could see. Therefore, the Inverter power source was hidden also, so as after the battery was completely disconnected, the engine conversion circuit ran off of the alternator installed under the flywheel. The Briggs stator of yellow+ yellow wires is capable of 20amps dc current. The ignition only operates during about 34% of flywheel turning, so as the wattage from Inverter box is reduced by 34% also. So as current delivered in DC pulses was 6-7-10 amps DC., The hidden Inverter box was being operated in the upper region called "SURGE current" which these boxes are capable of. The pure sine wave type output boxes give much higher surge currents, than the modified sine wave type which is square wave pulses waveform on an oscilloscope. Remember the significance of the very low duty cycle. So now you know. The 400watt green Inverter shown in videos,was not used-, not hooked up, not because it couldn't run the engine, but because it was too big to hide in cement block. The conversion circuit required about 100 volts and current same time. The other S1R9A9M9 electromagnet provided the magnetic field to change the timing to extend to negative late timing, and also provide required field for the tips of spark plug. The high voltage cable hooked to the heavy current same time as going to the zero ohms spark plug. Hydrogen gas evolved and fired along with generation of water vapor pressure.
    7amps X 110v = 770watts times .34 duty cycle flywheel usage, = 260 watts or less drawn power , plus the electromagnet current . Both draws are capable of the on board changed alternator. The black+ black wires Briggs alternator is the exact same low ohms as the yellow yellow. Just get the cheapest one. The 500W pure sine wave Inverter is about $40 called LVYUAN painted blue color. from US EBay shipping. Outer size 3.75" wide by 7.8" depth - IT FITS very loose in cement block, or 300W red LVYUAN 3 1/4" by 3 1/4" size.
  • russwr
    2008 S1R9A9M9 Georgia Water Engine
    I have some more tech data for you to consume. See also sheet Inverter output described by A I.
    I finally figured out why the green 400watt Inverter was not used. It was used OK on all previous car engines. Statement said it bogged down and quit as the attempt on operating Briggs 18HP. The You tube videos showed unit in background only, unconnected with clips on ground. It was placed there to mislead public. The engine started and ran in both videos. Previous MULTI CYLINDERS engines had used majority of wattage from 400W Inverter. The one cylinder mower engine required less watts power. The tech people used the brand power on board for 750W and 400W inverters. A MUCH SMALLER SIZE INVERTER FOR 110V AC WAS PURCHASED JUST FOR THE VIDEOS. The way "small" box fits in rear hole of cement block during the demonstrations. The 400W box does not!! The engine vertical shaft is in same hole rotating with great clearance from box. (box 3.3" X 3.3"300Watts) (They could of put the larger Inverter box in depression at ground level with cement block on top.) The demonstrations were keeping people from knowing all. Parts were not exposed. Parts were purposely kept in sealed plastic tub and also spray painted to keep eyes out. The Inverter pre made, allows the required 100 volts , due to the tiny electrodes of spark plug. The 10 amps initially came from car battery, then once engine running idle, battery removed, then the double alternators took over to run the conversion circuit.
    Dual alternators with just full wave rectification , without voltage regulator, provides higher volts and about 14.5 amps output capability.
    Here goes-- The positive battery cable clip touches starter terminal to run starter motor. Separate wire is also there going behind engine through diode. The input to inverter in cement hole, attaches to cathode side of diode. The diode prevents alternator from running starter. The alternator DC runs Inverter also, when battery removed.
    The S1R9A9M9 electromagnet provided magnetic field over ignition cable ( bare copper section) to form late timing from zero to about minus 34 degrees. The amps came from battery, then alternator DC at idle speed. Resistor in tub to limit current for S1R coils. The plastic tub connections needed for ground came from the exterior extension cord that was modified for extra long single wire to ground , and jumping the male end plug.
    The S1R coils is 100% on all the time to keep magnetic field at spark plug in-between firings. The power pulses to spark plug is on + off about 34% for ON duty cycle. (Flywheel going around 360 degrees)
    Plastic covered tub on side of Briggs engine contains S1r coils electromagnet, resistor, bridge rectifier for dual alternators, bridge rectifier for Inverter output, wire connectors, accessory spark gap, and wire joint putting output amps together with high volts going to modified zero ohms Champion spark plug.
    All previous car engines had 2 spark gaps in main circuit. The distributor rotor firing gap and spark plug gap. It helps to insure the plug fires rather than misfire.
    Mineral water was used for running mower engine with salt added that came from creek on the Georgia property.
    The dangerous ignition high voltage was on car battery only during the starting mode. (No series diodes protection bank)
    I was stalled, hung up , for long time on the 100volts source, power current means, difference between peak and average current, and higher high ignition volts.
    I found it greatly interesting to use the old style large clip clip board with mechanical pencil/eraser, printer blank paper, to form diagrams and notes over long period of time . I have many titled folders on different subjects related to the S1r project. (half cup of coffee helps)
    I will later be working on separate circuit to remove the waste spark cycle of Briggs engine. one and zero up counter IC and reset using Hall Effect sensor.
    Your comments will be appreciated.
  • russwr
    the several statements made by Nathren and Nathren's son Nathren, is that all earlier CONVERTED car engines were readjusted for timing to A T D C to about negative 34 degrees , as that approximate point allowed the engines to run smoother and provided water vapor pressure as a secondary force on piston, as generated at the lower end of piston travel. On the 18HP mower engine , the 13 turns wire over steel core section WITH the cable, as electromagnet provided magnetic field on the high volts cable and caused the spark time to be extended in milliseconds. He said to add more or less turns , so as to get the best setting for running engine. My own improvement design over his S1R9A9M9 coils assembly was to make the adjustment variable by varying amount of core under #14 wire + cable, as a pull handle. (Like turning loosened distributor on car engine) Hydrogen gas used in standard engine requires way late timing . I also increased the number of turns as per ratio change required, when changing from original 10 A current to 6 A current, to maintain the same magnetic field level. . Car engines are 4 cycle as well as the Briggs engine, but it has waste spark cycle that does no harm to a running engine.
    Each engine will run slightly different and a blanket statement cannot be made, as they all will require adjustment in different timing points. Nathren had made statement as to the available special degrees flywheel keys as used for different timing on Briggs engines. They all , however, are only for the small Briggs animal racing engine flywheels. I don't think he knew that. The Georgia technicians did not modify Briggs factory timing, other than adding magnetic field. I just assumed they were too lazy to machine a curved aluminum , slotted, mounting plate for Magnetron, as for being adjustable timing thereafter with screws and nuts repositioning.
    I am presently testing my latest S1R coils as 10kv cable included, rather than bare wire or insulated hook up wire, or 30Kv cable, so as for getting a constant recurring 100v leakage transfer without shorting. The wooden flywheel arrangement with Briggs ignition works well with series inductor coil and diodes. Later, I will blend in DC current to spark plug with water solution and protective diodes section. The water solution presents ohms resistance and would raise up the input voltage required, as also tiny electrodes.
    One of the original web forum paragraphs by Nathren , said in broken words, that there were other parts than the S1R coils in the plastic tub on side of mower engine!!!!!!! This was when he and son stopped saying anything more their set up as too much attention was received, and non-knowledgeable people had gotten hurt trying to duplicate his engine set up.
    When the man, "Smack ", showed up, at his property after 1000 miles driving, the episode was on video tape and we could see what was going on. The wiring on failed running 18HP was not done the same as during the 2 successful You tube videos of 2008.
    The Nathren back porch engine test was wrong also, as he was attempting to run engine with S1R coil as in induction type mode,- not with current output going direct to spark plug as needed. In one of the published answers to people's questions, way back in time, he said the output 12v current wire WAS CONNECTED to spark plug . (not repeated again)
  • russwr
    The 2 insulated wires used in the S1R coils assembly were taken by Nathren from a used harness of riding lawn mower chassis. This is the exact same. I know, since I bought the Briggs harness for reference. #14 gauge insulated stranded wires as red and Gray. He even mounted a USED steel nail, as it was bent. (see photo). My contention is still, that the joint on the S1r coils had 3 wires together. When Nathren tore off the 3rd wire to take unit in house for picture, he used knife instead of proper "wire stripper cutter". The proper tool makes a clean straight cut, not leaving frayed copper wire ends exposed. You must refer again - see- the blow-up photo and see the angle BACKWARDS of "folded" Gray + red colored wires. The 3rd one sticks straight out frayed . The thickness of the tape wrapping is also too large also for just 2 wires. When the other take apart video started , he placed unit on table , as same one with BENT nail. The joint was changed beforehand , so as the public would not see the 3rd stub wire fall out during the take apart video.
    The other notion had to do with him saying that the Inverter box could not be used with the S1r coils. It would just bog down and quit. That there assumes he had already tested the Inverter on the Briggs engine. He just LEFT the Inverter disconnected and the extension cord ,in the background of the 2 videos , instead of removing them before hand. The brown extension cord as a "Y" is also there connected to ground. The cord would act as a very LONG wire when you bridge together the male plug end with wire jumper or metal piece. I spent a very long time on this stuff. This hook up with extension cord is same as was used on all the car engines. Return line direct to ground under spark plug, not through an engine casting. - Helps with the time in milliseconds and lower resistance.
  • russwr
    Nathren and the 3 tech people in Georgia , 2005-2019, used the brand name (Power On Board), for the 3 types of inverters they used. 750Watt, 400Watt and I just ordered the other one called 150W as the plug in types for cigarette lighter.( DC to 120v AC) The small one may be important because,, with the outer plastic casing removed, The switching transistor circuit would FIT INSIDE the plastic deli tub on side of Briggs 18HP. Remember, 100 volts is also required to add to the low voltage main power and 6-10 amps, as going to spark plug along with the high voltage. There is a starting mode where flywheel turns slowly, and engine idling mode at faster RPMS. At both modes , the 100v is required and as DC with bridge rectification. Series current limiter resistor also put in, as it is not the main power source.
    My other idea was to hook up a tiny PC Board type miniature relay with 2 sets of contacts, with 12v DC coil, to act as a vibrator with capacitor added. Nathren had said in the web forum, that there was no capacitor in his circuit! He however, being non-technical person , may have meant "condenser" , as a play on words! Sen me your comments and questions. I will try to keep you updated.
  • russwr
    I just wanted you to understand here about this 100v as another added in requirement for the Briggs water engine. The original web forum in Georgia started with the car engine conversions and the paragraph was about the car engine fender test (60turns coil test). 60 turns wire over steel core and also on the heavy THICK insulation of car plug wire. 12v DC through coil to series amp gauge reads 20 amps to an electrical load. When high volts fires, it induces reactance ohms into coil that reduces the current to 12 amps. (on + off 20 to 12A) There was no statement as to why it was done. We also know that there is about 100 volts induced into the low volts line. Now,,,,, on the mower engine, the S1R9A9M9 triple coils electromagnet has BARE copper wire that induces 100v into regular insulated hook up wire. Because of no insulation, the other coil is NOW ONLY 6-7 turns. I meter measured this several times with high volts pulses, and we always get about 100v transfer leakage induction with less or just some insulation. The Bare does occasionally short, regular insulation also occasionally shorts, 30kv insulation has no transfer, I am now using 10kv China white cable for tests and it should give 100v. This may be how the 3 tech people got their 100v on 4cyl tractor, 4cyl, 6cyl, (2) v8 cars, v8 engine stand, mower engine, and with diodes added, for the tiny electrodes for spark plug DC electrolysis. Either that, or a 2nd separate wound transformer was used as earlier mentioned.
  • russwr
    If you haven't seen these movies, then you should plan on searching for them soon. ------(1) Free For All 1949 with Bob Cummings and might be on Youtube based on true story from 1935, (2) Mythbusters episode DVD called Exploding Pants-contains the fake on purpose setup of car engine to run on hydrogen from water cell, (3) The Water Engine 1992, (4) Chain Reaction 1996 about Cold Fusion Energy, (5) documentary called It Runs On Water, (6) The (2) You tube videos by S1R9A9M9 in summer 2008 of Briggs self running, 18HP mower engine conversion of water in carb to spark plug electrolysis with 10amps DC current, late timing, electromagnet field over plug wire and piston firing from power of Hydrogen gas and water vapor pressure same time. Battery was removed, engine runs on the dual alternator output after starting, with 12 magnets under flywheel.
  • russwr
    Can Radiant energy pass THROUGH a spark gap and on through series circuit , if it's in a small vacuum chamber? There is way less dissipation into ambient air, and the energy may be useful downstream. In 2005-2008, A sealed extreme high efficient vacuum dual coils relay , as originally for an electrical 60 cycles traffic signals pole box, was used with engine experiments, to generate more efficient hydrogen gas from water. The engines would run with spark plug electrolysis, but only with the special relays applied to pass both high voltage and 7amps current! (not used for a relay purpose, but for contacts, diodes and inductors) I recently built one with Carlon sealable 4" box, vacuum gauge, valve, and Tesla spark gap with magnets, 1.75millihenry coils, diodes, cap and hand vacuum pumper tool. Not tested yet.
    See one of Nathren's / S1R engines running,- S1R9A9M9 You tube videos 1+2. It was started with battery. Battery disconnected. Engine ran on the 12 magnet alternator , - self running sustained with 10amp draw. The high V. came in exactly after the cathode of diode inbetween the 2 series coils, then spark plug. The 4 technicians in Georgia called them "The Magic Relays". The web forum shut down. They never figured out the secret!
  • russwr
    ####Nathren used his triple wire hand wound electromagnet to pass 12DC and SUPERIMPOSED 100v pulse to follow same output to spark plug. He said about 2008, that lawnmower engines would fire spark plugs and actually RUN at electrolysis for forming hydrogen fuel and fire same , for running engines. 6-7-10 amps plus 100 volts was required. His set up did not show any other parts capable of 100v. So,,,,,,, with a bare copper wire at high ignition voltage with inductance leakage transfer voltage of superimposed 100v across to the 12v line of insulated #16 gauge wire, the amps are AIDED by the 100v transfer? I actually measured this with neon bulbs meter.Several other guys got 100v shocked while holding the 2 insulated wires! The spark plug electrodes are tiny in engine, - for cell generating hydrogen, but he said that 100 volts was required. He MAY HAVE added an inductor coil to get get flyback volts, but requires extreme short pulse, such as fast switch. The only other option is the "Tab" terminal engine shut off ,underneath coil, on opposite side of the Magnetron ignition. The primary negative minus 130 volts is what runs the secondary of Magnetron. I found out from bench tests, that adding a resistor to terminal, it can be used as source voltage , without shutting off engine. The duty cycle is only 34% on the flywheel. See his engine running at You tube video 1 +2 S1R9A9M9. Ignition high voltage is a type of AC. See image of s1r coils assembly (electromagnet).
    His 1978 V8 car conversion for water to hydrogen, had 110v inverter with series l coil, diode. l coil. diode to plug. RADIANT ENERGY pulse from the abrupt turn on of diode after high volts pressed EXACTLY on cathode in between coils, diode off, and released back to spark plug, when diode back on. !!!
  • russwr
    Another update regarding the S1R9A9M9 system. I rechecked the bench set up for the "capacitor 70" add on circuit . I got it working to fire spark plug at about 10kv in air. The secondary side was also through 2 FR607 series diodes and through the anode side, and through a China inductor 2.1millihemry. The Diodes represents 1/2 of a bridge rectifier from a dc power supply. The inductor is used as another required means for slowing the spark time. The value of PF caps in series increases the spark strength. First ADJUSTABLE spark gap tester fires from initial ignition coil. At same time also charges up the PF caps in series with primary 8 turns 20kv white China cable.on ferrite closed loop core. The other end wire goes to ground. Alltronics UU ferrite core set with measure and cut 1/16" peel and stick rubber to protect windings from the high volts touching metal core. The 2 halves are held together with 2 spring type hose clamps 11mmm center. The secondary was 30 turns #16 gauge solid hook up wire as it has to carry 6-7-10 amps. (Zero ohms small engine spark plug) As secondary fires, it is supposed to go through the PS 1/2 of bridge rectifier and on it's way through the S1R9A9M9 electromagnet coil, and the L coil and to engine spark plug. The methodology of this circuit is to allow for partial ISOLATION and eliminate the power/energy wasting series protection diodes bank that would be inbetween PS and ignition voltage.A higher PS output voltage needs higher current draw from battery. A lower battery draw is the resultant if using the Capitor70 circuit according to him. You need the internet calculator for L C resonance frequency near 649KHZ .Primary coil as 100 microhenries. A hand meter for capacitance and inductance is needed. In air, spark gap is 3KV per mm. A Briggs engine has listed as compression increase of 2-5 times higher voltage spark. The low cost China oscilloscope and probe divide by 10,000 allows for measuring the high voltage. DSO 138 and plug in PS ,and Hantek divider probe HT-25. Other items needed as jumper wires, dual set screw wire connectors, fuses / holder, and determination. I am hoping to integrate this new circuit into the original planned S1R9A9M9 final circuit on Briggs engine. (Questions??)
