Fields/Forces, Form (Velocity and Volume) and Experience/ Influence
The velocity and volume of a object determine the quantity of forces which are associated with that object providing its has a quantity of velocity or volume larger than zero. In a isolated representation of each force not representing the quantities of the other two for any of the given examples where momentum is, U, gravity is, G and magnetism is M, volume and speed being V and S (Speed).
VS = U, VS = G, VS = M,
___________________________
When there is a attracted object and VS is re associated with the object attracted not considering the attraction (being a change in speed) and its effect on the object causing attraction’s velocity and volume and subsequently its fields, the magnetic pressure (Mp) and the gravitational pressure, (Gp). Again presuming the attracting objects volume and speed to be constant irrespective of modulation by change in other synchronously existent forms/objects or the change in speed of the attracted object to cause the following relationships:
V is proportionate to Mp while Gp is volume times speed (VS = Gp).
The influence on the universe can be revocable while is simultaneously to a varied degree irrevocable, the influence being variation in quantity. The influence is specifically on existing field/s (gravity/magnetism) and is to cause effect on forms or is not dependant on the fields source being manipulated by influence.
In order to capture irrevocable influence the sensitivity can be varied accordingly by manipulation of the modulated objects velocity, utilising any pre existent field.
Sensual phenomenon is a product of change in any of the given fields, experience is sensual phenomenon.
As a result of the decay of a field by the square of the distance, VS = M, and VS = G, change in the velocity of a object causes a modulation of the velocity of all objects that synchronously exist in the same moment as the change in the velocity of the primary object, this resultant field fluctuation serves to create a interactive series of forms where by no relationship can be observed between two forms as a isolated relationship as is mentioned in the second statement, this relationship can only be analysed to the highest degree of accuracy by enabling the ability to isolate the relationship desired to be observed/ measured via a complete record of the field fluctuation capable of being assessed for the same point as the measurements themselves are made, thus enabling the cancelation of the influence of everything which is not desired to be observed.
As a consequence of the relationships, VS = G and VS = M with respect to what the represent they enable the continual accumulation of velocity which is a product of the acceleration cause by, G and the subsequent change in G which is characterised by a change in velocity. Internal acceleration (acceleration by the fields of the volume accelerating) is the characterisation or archetype of form. The archetype of a synchronously occurring series of forms is analogous to “white noise”, a nearly infinitely long and nearly infinitely intricate series of changes in quantity.
A divergence being the product of the interaction of multiple forces while date is the deduced measure of speed of constant frequency. (Force being used to represent both magnetism and gravity)
The divergence’s volume’s rate of increase is proportionate to the date for a fixed/ constant agreed upon time for the divergence to exist, the time as previously mentioned (being a measure of the period of divergence from motion) is also proportionate to the date.
Where the rate of increase of divergence volume is - Vr,
The time the divergence exists is - t
The date being - D,
Vrt = D or Vr times t equals D.
For any rate of decrease the divergence volume, Dv is inversely proportionate to the date (D).
1/Dv = D
The specified relationships (Vrt = D, 1/Dv = D) again are subject to the archetypal sequence of change in fields that is continual (non repetitive) and a product of the existence of form and force. Thus the highest degree of accuracy can only be attained via irrevocable influence (with respect to the equations) for the function of superimposing all non specified influence (in the equation) onto the measured quantities.
For the rotation of a disc while it has motion in the form of a orbit about a central point with radius (the orbit) , C.
The volume moving in the direction of motion, (of orbit) B, and the volume moving against the direction of motion, H.
C (the radius of orbit) offsets the stated volumes.
For counter clockwise rotation and clockwise orbit with a supposed attractive and isolated gravitational force on the disc the square of the radius (C2) is proportionate to the net gravitational force/pressure on the disc while the rpm, (R) is inversely proportionate to the net gravitational force/pressure on the disc. (N)
C2/R = N
For clockwise rotation of the disc and clockwise orbital motion the forces of the disc as net quantities (for the whole disc) supposed in their isolation of measurement from one another when magnetism is given by (M) and gravitation (G).
R/C2 = M, R/C2 = G,
The consideration of both situations (C2/R = N, R/C2 = M, R/C2 = G) is had in relation again to the caused modulation of gravitation and magnetism in all forms synchronously existing by the changes in gravitation and magnetism of the disc and also to the pre-existent fluctuating field strength caused by the interaction of synchronously existing forms. Considering the first example to be present in a atmosphere motion can be a subsequent cause determined by the buoyant force on a object, seen as the gravitational attraction decreases inversely proportionate to the R.P.M then beyond a certain point the two forces become imbalanced, the buoyant force is a product of pressure difference (over/across the disc) and surface area exposed (of the disc).
The date being - D,
1/Dv = D
C2/R = N
R/C2 = M, R/C2 = G,
