Hi totoalas,
This isn't anything sophisticated. I'm making a base with CD Rom motor and plastic rotor holding two or one neo magnets on the surface. I have an old cup warmer with burnt heating element which should work as enclosure - base. Same idea as magnetic stirrers used in the lab but cheaper. Originally, warmer had metal round top which I'll replace with either glass (if I can find my glass cutter) or lexan. Cross shaped teflon coated stirrer will be placed on the bottom of glass vessel filled with water and placed on the top of my base. I ran some tests and I got nice vortex inside the body of water. Next part will involve either three strong neos placed equally around the perimeter of glass vessel or coil arrangements. In the latter I was thinking of feeding coil with amplified sine wave of certain solfeggio frequencies. I didn't decide yet.
If you're going to inject ozone into the water additional filtering with UV lamp wouldn't be necessary. Ozone is very potent and will destroy all biological impurities. Just my 2 cents.
Vtech
Vtech
