I have been messing around with the idea for years, and about a year ago I saw something like it here (https://www.indiegogo.com/projects/g...untries#/story). I have seen small ones that light an led but I want to build one that could power something bigger. I have been trying to find a way to power lights for a horse-shoe pit at my fathers so I would need about 75 watts or so to power three 25 watt leds. The question i have for all you fine folks out there is...is there any way to calculate the exact weight and fall length needed to produce a certain amount of power I understand it can't be exact because every generator would have a different efficiency but a "perfect scenario" equation.
From my research one horsepower is 776 watts...With one horsepower being the force required to lift one pound one foot in one second. So am i thinking correctly to assume that a one pound weight that drops one foot in one second would put out 776 watts? or 10 pounds droping one foot in ten seconds? The way I plan on doing this is to hang a pully system from a tree so I could have a long drop length about 50 feet....so in a perfect world I could lift 60 pounds and make a generator that would let it drop at one foot a minute and that would give me 776 watts of power for 50 minutes. or am i missing something and way off?
The "original" idea i had about this was thinking of makeing a workout system that instead of lifting weights for no reason you could link it to a system like this so while your working out your storing the energy in a weight then let it drop after the workout to use the power in your house....why waste the energy of a workout when you could use it
