Aaron,Originally posted by Aaron Murakami View PostRon, if you check the resistance between the input terminal of the wires you spliced in to the spark plug cables to the terminal in the boot that slips over the plug is relatively low and you use non-resistor plugs, they should work fine. What is that resistance by the way if you can measure it?
The coil you have looks simple enough - basic autotransformer coil with the primary if that its the red and white wires on the input and the hv output has a common ground with the ignition coil, you should have an easy job. I don't see what the Street Fire or other common MSD will not work. If that red is the primary + and the white is the primary - , then it should work.
You hook it up like that depending on if you have points (top) or an electronic pickup (bottom). That is the first step to get the plasma on your Toyota.
The plug wires from the red section are solid wire for a direct connection to the plug. I spliced into the original wires leaving the top section coming from the cap original to help reduce RF?? I was under the assumption that when I build the plasma unit I would need to connect directly to the plug? I did the wire modification to allow that without having all wire plug wires which I understand can cause RF problems with the computer, right?
Here's the full PDF http://documents.msdperformance.com/5520.pdfOriginally posted by rokan View PostI can't enlarge the instructions to be able to read them?
Connection to the top of each Spark Plug
Thank you for sending that!Originally posted by Aaron Murakami View PostHere's the full PDF http://documents.msdperformance.com/5520.pdf
Ok, now I understand that hookup but I also thought we needed to connect the extra strong spark directly to the top of each non-resistor plug to get plasma?
When you hook up the MSD/CDI, you are already getting a stronger spark at each plug - from coil, thru distributor directly to each plug.Originally posted by rokan View PostThank you for sending that!
After the MSD/CDI is hooked up, then you add diodes. 4 of them.
If you're coil isn't suitable for capacitive discharge, I'd recommend this one: https://www.amazon.com/gp/product/B0...SIN=B002Q363XM
After getting the cdi/msd hooked up, post your results and then we can diagram the diodes to the top of the plugs. That will be super easy.
A lot of work was necessary in order to support the Plasma engagement.
Here are my first impressions:
Trying to lean the fuel mixture, it is possible to intervene to the time the injectors are functioning.
"Using a stock file from a 1992 G60 Passat syncro, and ECU temperature of 87 deg C, an IAT of 32 deg C and a battery voltage of 14, I get the following results adjusting the CO pot value:
800 RPM at 37.5 mbar:
CO pot setting vs Inj PW
0 ; 3.102 ms
200 ; 2.620 ms
400 ; 2.540 ms
495 ; 2.480 ms <-- value where fuel is neither added nor subtracted
600 ; 2.416 ms
800 ; 2.328 ms
1000; 2.254 ms
1200; 2.202 ms
1400; 2.156 ms
1600; 2.120 ms
1800; 2.088 ms
2000; 2.062 ms
6300 RPM at 175 mbar:
0 ; 9.146 ms
200 ; 9.088 ms
400 ; 9.042 ms
495 ; 9.030 ms <-- value where fuel is neither added nor subtracted
600 ; 9.006 ms
800 ; 8.984 ms
1000; 8.960 ms
1200; 8.950 ms
1400; 8.938 ms
1600; 8.926 ms
1800; 8.914 ms
2000; 8.904 ms
These values would only come into play when the ECU is in open loop, otherwise the O2 sensor takes over.
http://forums.fourtitude.com/showthr...ng-copot/page2 "
In my system the limit is the setting at 1900 Ω.
By doing this adjustment, (at 1900 Ω), I am observing the following phenomena:
1) Plasma on/off and the needle of the tachometer jumps, just a little bit, so the system affects the operation. (This is at any fuel adjustment).
2) The engine's temperature remains on the same level as in the normal fueling. (The normal value is at about 490-500 Ω).
(This is checked only under very light duty, since I haven't the time to check it under normal or heavy operation).
3) There is a substantial drop in the performance of the engine, especially at the high revs.
4) The first measurements with the on board trip computer saw an, almost, vertical slope in the reduction of the consumption.
Saying these, the only point for anxiety is the drop in the performance.
Any thoughts?Last edited by Hellenic Vanagon; 05-18-2018, 08:42 AM.The Syncro Heresy
Just in the case you know that nothing better can be done, please don't worry. The Plasma, in my case, supports the ignition functioning with the surface discharge spark plugs, which:
1)Allow the use of the regular petrol 95 Ron instead of the super 98 Ron, without any compromise in the performance, (on the contrary, being immune to detonation and promoting a better combustion), the difference in Greece being ~ 20%.
2)Reduce the consumption, at least, (I give the official estimation), 6%.
3)Are susceptible to fouling if not supported by a proper, high energy, ignition, (here comes the Plasma).
Thank you for your time, (and knowledge).
Very happy with my Plasma.
#1 The distributor is bypassed for the plasma, which is driven directly on the spark plugs, with tv cables.Originally posted by Aaron Murakami View PostAre you discharging plasma through a distributor? You can bypass it and go straight to the top of the plugs.
Are you a machinist? Perhaps you can try to make some Robert Krupa Firestorm plugs to test with the plasma.
Can you post a video or pic of the spark/arc?
#2 No, I haven't the equipment necessary to make them.
#3 I will try to catch the double discharges and I will post them.
Theoretically speaking, is it possible to have those two discharges in parallel, having between them a tiny distance, or they must coincide absolutely, as at 95% of the events happens ?The Syncro Heresy
I'll have to look at my old pics to see if I see them at the same time. Of course it is only possible for the cap to discharge after the HV normal spark jumps, but could be so fast the high current impulse from the cap jumps the gap before the spark is extinguished. That supports my belief in the accelerated discharge.Originally posted by Hellenic Vanagon View Post#1 The distributor is bypassed for the plasma, which is driven directly on the spark plugs, with tv cables.
Please look over this doc carefully: http://www.hho4free.com/spark%20plug...lasmaplugs.pdfOriginally posted by RichardTIG welding uses a tungsten electrode which can be purchased for $30 for 10 pieces (makes 20 sparkplugs?) of 1/8" diameter by 7" long.
Have you heard of anyone trying this material for the center electrode in the sparkplug?
