Hello forum, I have converted a 12 volt battery using a virgin never activated unit. No sulphuric acid. I used a combination of Plengo's and John Bedini's chemical mix. I posted the mix on the Battery Conversion thread. The battery took its first charge and lasted 4 days down to 2 volts lighting 46 LEDs, because it is all I have. I am noticing that it uses a lot of water when charging and discharging. I am hoping it will stabilize itself and use a minimal amount of water as it gets used more. The battery is now on the charger at a 2 amp charge. The first use was to power 2 ham radios with continuos volume until it showed 4.5 volts. I then powered the 46 LEDs until they were slightly dim down to 2 volts. And then I just wanted to recharge it. NOTE: It does get warm when charging.
I also used the same formula to make 1.5 volt batteries and the dry mix puts out 2 volts. I am now looking for the correct fitting parts to make D cells, 1.5 volt batteries.
