Hi guys.
How do you work out how long a battery will take to charge. What is the maths formula to work it out. Thanks.
in a normal situation with a normal charger you can use the amp hour rating of the battery and then use the current supplied by the charger in amps to give you a rough estimate, it also depends upon your charge termination voltage.
. a really small single coil bifilar machine will have a hard time charging a large capacity battery, like a car starter battery. you have to size the battery for the coil© 2012–2026 A & P Electronic Media and its licensors · posts © their authors · Copyright & Archive Policy
