John has the new linear regulators available from the conference. the new device puts out pure DC from an SG running in generator mode. the output is adjustable and you can dial it in for the type of battery you are using. they are the same price as the large comparator.
the operation and theory of the device is shown on DVD 37 and was presented at the conference this year. it is one of the links in the chain of using the SG to power your loads. you can put other things besides batteries on the back end.
right now the current model provides about 2 amps for loads.
once the battery is restored by pulse charging you can continue to use the SG by adding the regulator circuit to run small loads and DC charge batteries.
