I have designed a PCB for the Tri-Symmetrical 3 Battery Tesla Switch V1.0 for the circuit in post #71
http://www.energyscienceforum.com/sh...ll=1#post22331
I have added 3 capacitors, each of the 3 capacitors are connected between each of the 3 battery negatives and the 3 phase bridge rectifier. These 3 capacitors are DC blocking CAPs and make sure only AC can come from the 3 battery negatives.
Copper Side
Composite Drawing
Silkscreen Layer
Drill Guide
Assembly Layer
Parts List
9 x MJL21194 Q1.x - Q3.x
9 x H11D1 P1.x - P3.x
9 x 6 DIN IC Sockets P1.x - P3.x
3 x SBL3040 or SBL3060 Schottky Diodes in a TO-247 package (D1&D2), (D3&D4) & (D5&D6)
6 x 5mm Super Bright Red LEDs LED1 - LED6
3 x 5mm Super Bright Green LEDs R.LED1 - R.LED3
4 x 1000uF/2200uF electrolytic Caps C1 - C4
6 x SB560 Schottky Diodes or Simalar D7 - D12
Here are the PDFs of the Copper Side and the Drill Guide. So it is easier to print to scale.
Drill Guide For (TopLayer,Botto.pdfTopLayer.pdf
I have only just designed this, I haven't made a circuit board from the PCB layout yet. Any feedback on improving the PCB layout is welcome. I was not sure about the size of the pads. If anyone makes this, first check, if I have the MJL21194 footprint is correct. I used the footprint of a TO-247 package.
Enjoy
Most
Kindest
Nityesh Schnaderbeck
Copper Side
Composite Drawing
Silkscreen Layer
Drill Guide
Assembly Layer
Parts List
Enjoy
Most
Kindest
Might be helpful to label the battery connections on the assembly layer. Took me a while to figure out where they are.
