So based on this:
I've been doing this:
I neglected to draw in the trigger bulb regulator, but I think you know where it goes - on the trigger... :-)
On mine this was tricky to tune, it did not want to start right off the bat. I went back to the normal primary battery with charging battery, tuned it, then switched to the TS hook up and it was much easier.
Not going to claim anything, but if you have 4 batteries and an SSG lying around, it'll be worth your while to give it a go.
try it with 1 ONE transistor first just in case you hook something up wrong.
Kind regards - Patrick A.
