Can anyone give me a link to the 1 watt 470 ohm resistor on Mouser. I am not sure about which one to order based on what is offered on Mouser.
Hi,Originally posted by mche36500 View PostCan anyone give me a link to the 1 watt 470 ohm resistor on Mouser. I am not sure about which one to order based on what is offered on Mouser.
1W 470 should be available in any Radio shak not a very critical tolerance item..
are you buying in quantities..??
Hi mche36500,
Here's the link you requested. At least this is the one I would get if buying from Mouser. https://www.mouser.com/ProductDetail...uDN2p3v8YlQ%3dOriginally posted by mche36500 View PostCan anyone give me a link to the 1 watt 470 ohm resistor on Mouser. I am not sure about which one to order based on what is offered on Mouser.
However, I bought the 8 transistor kit from Teslagenx which has everything you need, and all the critical components are already matched! You will probably spend more if buying enough transistors and resistors individually to get everything matched for best performance. Check it out here. http://teslagenx.com/kits/tx-sg8.html?category=kits
