Secret of t. Henry moray's crystal by john bedini
  • Secret of t. Henry moray's crystal by john bedini
    SECRET OF T. HENRY MORAY'S CRYSTAL BY JOHN BEDINI
    T. Henry Moray was known as having one of the most profound free energy devices that produced massive amounts of "overunity." The key to making his system work was a crystal that Moray worked with that was referred to as a Swedish Stone. When Moray was on a mission in Sweden for his Mormon Church in 1912, he was researching crystal radios and was looking for minerals that could work just as well or better than the galena crystal. Claims for what this stone was appears to have been speculation but somehow, John Bedini managed to replicate it at a lower power level than what Moray was doing. Learn more about T. Henry Moray on Peter Lindemann's site here: http://free-energy.ws/t-henry-moray/
    This crystal is actually the secret behind Bedini's "Ionic Line Amps". John did a famous demo with these at an audio show in the early 1980's - he would play a record or cd into his pre-amp, which fed a larger high power amp that powered some high end speakers with high volume. He then disconnected the large speaker cables and put one of these amps at the output of the amp and another at the input of the speakers. He then connected both of those ionic line amps with tiny 30 gauge wire. Now anyone that knows even the smallest bit about stereos knows that if you crank up the stereo with this small fine wire that it will probably disintigrate them with that much wattage. However, as John was often doing the "impossible", it worked perfectly! How?
    John said that the wires were of course too small to carry that signal and the wires acted more as a guide - while the real power was moving through "hyperspace" or what is also known as "counterspace" from transmitter to receiver. Read this: https://audiophilereview.com/analog/...of-voodoo.html
    A 27 minute video cut from a larger presentation that focuses just on what the formula is, how to make it and the circuit to use it in will be disclosed very soon. The price will be $37.
    Wow!! Great to know Aaron!!
      Aaron,
      Did you ever finish the video?
      Monty
        Originally posted by nikola-wan View Post
        Aaron,
        Monty
        Monty,
        John's presentation is complete - everything that was made available to me is in the download package.
