Ya,
Sometimes it shows up that way, with the oscillator you never know until you try it. I have seen them run hot to cold depending on the condition it is running in. If the oscillator is big enough it can do some strange things with the fields. I have dried batteries right out when the conditions are right. Quartz clocks go nuts sometimes around them from across the room. One time the time changed on a clock I had so I took off home only to find out it was only 8 o'clock yet the clock said 12:30 this clock has never been the same. I have repeated that many times just to make sure the oscillator was the culprit. I have watched SSG machines goof with cameras in some of the videos Tony filmed me in, it can be seen if you watch very carefully. At the conference with the Ferris wheel the video monitors facing the audience had lines in different colors running at the speed of the machine in stand by rotation. yes, seen allot of unexplained things with cold energy so now I want to work with the current end of the energy the hot part. I find a hidden current in the current and I know soon one of you will see it. The SSG can use it in forced mode. it just takes time to see it, but you will.
John
John
