Dear John
I have constructed and successfully run a 6 pole machine of your design. Bedini Machine SSG.
However I have a nagging question that I simply can get no answer to. So I thought I would ask you.
On your video " Energy from the vacuum science series part 2".released in 2007, at time index 43.06 you describe the magno-static pulse.
How the iron gets charged by the permanent magnet then discharges producing the pulse.
You then show 2 devices which seem to behave backwards.
The first is a pendulum type device which swings back and forth until it swings continually in one direction."Over the top is the comment".
And the second, 2 rotors facing each other with 4 magnets set in each rotor with a coil set in between the rotors.
The rotors are spun and the device keeps spinning.
Neither device takes any power in.
Both devices create a pulse that appears to repel the magnet inducing the pulse . How?.
I have constructed a reproduction of the twin rotor device but the field effect it creates when the field collapses is a breaking effect in the device rather than
a repulsive effect required to run it. The pulse attracts the pole that induced it rather than repelling it.
Am I approaching this all wrong?. I know the Bedini machine creates an attractive action upon the rotor to keep things going which indeed
I am experiencing but the 2 devices shown on your video have me intrigued they seem not to.
when it comes to John's technology, sometimes too little..
