My home-made 10 coiler
    Fantastic , very clean looking , professional work. I will do this in the future for sure ! But first I have to learn all the tips and tricks (tunning,cap dumps) before going into a x-coiler.
    Please , I am very interested how you put together your spools. Are they from wood or plastic ? One piece , or glued together ? How about the wheel, I would appreciate more details. The front is CNC'd or cut out or more parts together ?
    Thank you
    PS: more photos , small details ))
    my work here :
    https://plus.google.com/u/0/photos/+...22301631177969
      Hi Magnus,
      Great job of construction! I know good work when I see it and you have done a fantastic job! Just curious......how much current dose this unit draw when under load charging those big 44AH batteries?
      Bud
        Thanks for the compliment Bud
        When I use 3 44ah batteries as primary,and another 3 44 ah as the secondary it draws 2.6 amps, connected in parallel ,12 volts.
        Magnus
          When I run it at 24 volts it draws about 5 amps.
            Hi Mike
            Yes,the batteries charges up to 15.6 volts and they will rest at about 13 volts,which is higher than new ones,they where resting at 12.6 when they where new.
            No I do not power my house with my 10 coiler,I have not done much research yet but I have been charging batteries,it seems to be working very well.
            I am still reading and trying to learn more about this technology .
            When I saw John Bedini´s 10 coiler I thougt it was such a beutiful machine that I had to have one for my self.
            rgd Magnus M.
              Very nice machine, inspiring.
              George N.
              • #22
                hi magnus
                Looks great
                What size base resistors do you use in your circuits?and what size branch resistors?
                cheers jason
                • #23
                  Brother, you got mad skills!! Well done.
                  Save The Planet!
                  • #24
                    That is a very nice machine. well done.
                    • #25
                      What a FIZZZ...hey !!
                      SO Magnus, what can you tell about your charge specifications ?
                      What can you charge with one battery ?
                      Also, I can tell you like neat things, you are taking a awful job of looking like Space Oddyssey...and that DOES look like it !
                      You could almost sell those like a "big company", folk !!
                      Regards & congrats for the big-D Design !!
                      • #26
                        • #27
                          Hey my friend Magnus M.;
                          That is a very nice machine. You can send the your schematic?
                          • #28
                            Originally posted by Magnus M. View Post
                            [ATTACH=CONFIG]2360[/ATTACH] [ATTACH=CONFIG]2361[/ATTACH] [ATTACH=CONFIG]2362[/ATTACH] [ATTACH=CONFIG]2363[/ATTACH] [ATTACH=CONFIG]2364[/ATTACH]
                            Hello!
                            Question: What is the function of the transistor 8. The coil of wire 8 or 9?
                            Thank you.
                            Sergei.
