Bedini oscilador radiante
Originally posted by min2olyI like the clean build, nice wheel too!
Ok remember you asked :-)
Dump (get rid of) the daftman layout - great for visualisation - poor for good charging/tuning. daftman layout is perhaps why many fail.
solder everything directly to the transistor.
put a capacitor in parallel w/ the power supply.
put nice thick leeds from circuit to the battery (no small alligator clip leads)
put the circuit right on the coil.
transistor may be too big for that small wire sub w/ mje130007g
and sub E/B diode w/ 1N914
or...
for that coil and that wheel the thinnest wire "I" would use is 20awg (0.81)
if you're going to replace it, go w/ 18awg
I like your clean table. This build is a VERY good first step!
Kind regards,
Patricio
Originally posted by min2oly1 Where to put the capacitor? In primary or secondary battery
- Parallel to your power supply.
2 Set LED thick. No where to put them.
- Not LED - "Lead" the wire leads. The wire that goes DIRECTLY from collector diode to charge battery, and the wire that goes directly from primary + to charging - . I spelled wrong (leeds)
3 Switch right in the coil circuit.
- Not "switch", Mount the circuit onto the coil or right next to it. the energy is traveling too far from your coil to the circuit.
4 You could spend some diagram with details
- No change in diagram, just get rid of all that extra daftman wire. solder your emitter/base diode right onto the transistor etc...
solder everything right onto the transistor
here is an example picture where everything is soldered as close to the coil as possible:
[ATTACH=CONFIG]2428[/ATTACH]
notice thicker wire lead from output diode to charge battery terminal.
kind regards,
Patrick
kind regards,
Patrick
