Here is the info on the RPM Sensor.
Circuit - Signal is connected to digital pin
Photo - Yes the bike wheel shaft does come out of the workshop wall.
The resistors are on a small circuit board under the bracket.
Sketch:
/* RPM sensor using a Reflective Object Sensor OPB705WZ from OPEK Technology
Using pulseIn() to measure a high pulse length in micro seconds
Reflective surface is aluminium dsk with two black quadrants painted on
Convert pulse time to RPM. Print out duration and RPM to serial monitor.
int pin = 7;
float RPM;
unsigned long duration;
void setup()
Serial.begin(9600); // initialize serial communication at 9600 bits per second:
pinMode(pin, INPUT);
void loop()
duration = pulseIn(pin, HIGH); // read HIGH, duration = 1/4 rotation
if(duration > 5000) // duration of 5000 micro seconds limits speed to 3000 RPM. This stops erroneous data caused by transient spikes
RPM = (15000000.0/duration); // (1000000uS * 1/4 * 60s) / duration = 15000000.0 / duration keeps calculation simple
Serial.print(duration);
Serial.print(" micro seconds ");
Serial.print(RPM);
Serial.println(" RPM");
delay(10); // delay
I hope this sketch is readable. Any suggestions welcome.
Peter
Sketch:
int pin = 7;
float RPM;
void setup()
void loop()
Serial.print(RPM);
delay(10); // delay
Peter
