erfinder, can you display or describe your hall switching setup?
<<<Overunity While Powering 2 Loads>>>
Hi all,Originally posted by Dave Wing View PostHi all,
Here are the remainder of the readings from the test run in the video.
1045HRS
primary 13.0724v
secondary 63.252v
1233HRS
primary 13.0760
secondary 63.519
1259 HRS
primary 13.0771
secondary 63.532
1419HRS
primary 130794
secondary 63.681
Any readings taken after this saw a decrease in voltage as per post number 3 of this thread.
I have been thinking on what has been going on in this circuit and have only come up with this idea. The extra energy was really there! But only there because the impedance of the 5 battery bank on the secondary was high, because I had a dead battery in position 2 @ 10volts (If memory serves the dead battery was located second, when going from right to left in the video, it was also acting as the positive going to the bulb). Perhaps the extra impedance of the lead sulfate on the plates of this particular battery, in the five battery arrangement brought the power winding coil and the batteries closer to true resonance, hence the extra energy appearing within the circuit. This however is speculation at this time though.
I will not be able to test this theory until Monday and anyone feel free to try it out.
That basically describes the full details of this event.
I have known about the trigger using energy for a while now and have commented on it in other sections of this forum a few times and yes the perceived problem is even stated in the SG Beginners Handbook as well. In the first place this experiment was purposfully not optimized for effiency in any way shape or form.
Sincerely,
At this point and to be honest, I am thinking the gains possibly were masked and have been hidden in secondary battery rebound, associated with a higher resting voltage on the back end, because when the load, across the positives, was removed and the power was cut to the SG, the machine charging the backend batteries, the resting voltage on the back end continued to increase above the state when the system was running under both loads and in balance.
What I speak of here possibly could be attributed to dead batteries seeking their resting voltages as I did have two batteries, not one as i said earlier, that were dead in the string of 5 on the back end, so there was a lot really going on with all this and I am not really sure one way or another of the true outcome, or what was initially stated when I started this thread.
I have not done anything more with this since I first posted my last reply... Some time ago.
