Originally posted by Ecancanvas
linear amp regulator.pdf
Guess what "it is a current source too"
yes, no op-amp current sensing needed, the output transistor is the current source. So 2 op-amps.So the circuit would look something like this
Linear Amp Regulator-npn.pdf
with 2 op-amps.Have a look at these links http://sparksandflames.com/p15.html
http://sparksandflames.com/p16.html
"Joster" Use star grounding. This means run all grounds to a single physical point, for your PCB design. This is also mentioned in the first URL. Star grounding eliminates "earth loops" and stabilizes the circuit.
A star connection, at the negative pin of the pre-filter cap, and a thick track (thickened with solder) from "battery negative" to the "negative pin of the pre-filter cap".(the 15,000uF one).
A star connection, at the positive pin of the pre-filter cap, so you don't have "earth loops".
A star connection at op-amp ground, this eliminates unwanted noise entering the high impedance inputs of the op-amps.
A star connection at the emitter of the beta multiplier would not hurt, and a nice "thick as short as possible track" (thickened with solder) between the "emitter of the beta multiplier" and the output device.If you wish to make extra measures, have star connections on all of the op-amp inputs.
All the resistors connecting to inputs/"summing points" of the op-amp/s connect to a single point at the input pin/s of the op-amps.
This is like designing a circuit board for an audio amp.
I will indicate the star connections on my future schematics.
