Ferris wheel thread
we also need to look at why there is capacitance in a coil. when you lay 2 insulated wires side by side and pass current between them the air gap acts in the same way as the separation in the 2 halves of a capacitor. hence we can use the terms inductive capacitance, because it is related to frequency and it can be manipulated .
I don't know if anyone was at the conference where Paul Babcock did his lecture on the math behind his coil array where he could weld 1/4 inch steel together using a big coil and a little tiny battery. he interchanged the inductance and capacitance formulas to show how the math proves it can be done. not important for now but I have seen these 2 formulas mixed in a very unique way to produce real work.
astable 555 timer circuit
we will need this down the road, so everyone print this out and sock it away for the future.
555 Timer: This tutorial provides sample circuits to set up a 555 timer in monostable, astable, and bistable modes as well as an in depth discussion of how the 555 timer works and how to choose components to use with it. The 555 timer is a chip that can be us…
a quote from JB:
My intention was not to hide anything you were free to touch it examine it and run it if you wanted to. I was just standing around to help.
John K take your monopole single coil machine and use the Bedini/Cole switch then shape the field of the bottom coil like I did. Do the timing wheel right use a hall and collect everything from the switch to the capacitor and dump the charge in seconds according to the charge rate, you will see.
John B
why all the info? we can build it without knowing how it works, and it may run, but if it does not we need to know why. but understanding magnets and magnetism is the key to all free energy devices. the magnet is a dipole and it pours out excess energy for years, way more than the original number of joules used to create it. we will eventually build and run all the devices mentioned on this forum. its all about the same thing, whether it is a permanent magnet or an electromagnet.
Tom i get an error 404 on the linkOriginally posted by Tom C View Post
this has been one of my favorite illustrations for years.....
'dual band flux path inductive reactance capacitive non coil saturating switched at the delta phi' sounds like a
to me
Tom,
All these links are a treasure trove.
Thanks for sharing them.
Here is the link that is messed up below.
Go to http://wmsn.net and you have more...
Patrick
to me
its not "demagnetization" per say, more like a manipulation of the field, like the radus patent, like leedskalnin, and like the coils in the ferris wheel. like I said we will all get where we want to go together.... we are almost there. just need to understand the operational theory behind the coil asymmetry in the ferris wheel. then we can build it.
I am assembling a timing disc right now. I purchased a plastic disc from tap plastics and some round ceramics from home depot. since I am making a small ferris wheel I am using 3/4 disc magnets. this is for the hall sensor.
here is an instructable for making a center finder. http://www.instructables.com/id/Make-a-Center-Finder/
360/16 = 22.5 degrees on center for each magnet. this can be done with a 1/2 inch drill bit and a 3/4 inch paddle bit. use a drill press if you have one.
======Adams%20Motor%20Theory.htm==== CUT PAST TO GOOGLE
FOR http://wmsn.net/Adams%20Motor%20Theory.htm
