Hello All,
As I understand it we are creating an electromagnetic pump. To oscillate the Bloch wall on the coil. That pumping action produces two things that we want.
1.) A siphon effect for non divergent Radiant energy.
2.) A high voltage transient spike.
Both of these things are transferred to the battery which causes the ions in the battery to return to their originating plates. In effect charging the battery without massive current flow.
Correct so far?
I have seen multiple references to using a master coil to trigger all of the coils for this effect.
Why?
Would it not be better to trigger each coil independently?
Triggering with a master coil would cause all coils to fire synchronized. Lower frequency of voltage transients. Less opportunity to siphon non-divergent, (read radiant), charge.
Minute differences in the fabrication and placement of each triggered coil would cause them to fire independently of other coils and thus create a higher frequency of transient spikes and a larger siphon into the charging battery.
Salamat.
Correct so far?
Why?
Salamat.
