Nice build. I assume the magnets are scalar north? if not then change them to scalar north. also all 3 of those copper bus pipes, need to have the ends tied together to for an inductance loop, especially the charge battery positive. also diodes should be voltage drop matched across the junction, resistors to bases should be exactly the same. your charging will go up if you close the charge battery positive bus.
pleas post pics of collector after diode, trigger at base. want to see the slope of the trigger signal.
Tom
Hi Tom C,
Above in the Highlighted is my doubt..
Tom
Hi Tom C,
