system for this set of runs with same kit as Branch:
21 inch rim- 16 ceramic mags- 4 TEK kit, 4x20/1x23 coil 130 FT w/welding rod core, 470 ohm base resistance, no pot, final resistor will be adjusted to have the unit pull 580 MA, no fuse simple circuit. 2 7AH yuasa batteries pulled from a old backup power supply. CBA 4 for load testing. both batts charged on a 1AU and are now being cycled on the CBA to determine true capacity. 80% D.O.D. will be discharged to 12.2 at C20
