Correct care of batteries with SSG's
    it is a must that you ssg will charge a good batt this is base line info you need so you can tell what the batt doing
    if good batt takes [x] time to discharge and [x time to charge ] a good base line to work off of
      hey guy
      thanks for the info
      just a snap queastion. how manny amps you pull on discharge?
      regards
      weasel
        weasel 1-2 amps unless is a big battery then more i think the norm is the c20 but c10 i do .
          hello guy
          bat is now at 13.81 volts for the last 3 hours
          i do a discharge now and see if we got it up a bit
            discharge tells all
            have you charged with 2 good batteries of the same size .how long did it take , was size are the 2 good bats
            you need to compare with a good charge cycle a 180 amp is a big batt i think my 16 trans would take a long long time to charge a good 180 amp if you have not charged a good batt and discharged it then youll never know if the ssg is setup right
            the only thing i diff after i know the ssg will charge a good batt is put a little bigger bat up ft
              hello guy
              as input i used 2 225AH batterys
              discharge was a bit dissapointing . it lasted only 15 minutes under a load of 4.5 amps
              but i knew in advance it was a bad battery for starting.... just need to get it back up slowly
              in the meantime
              first charge session after the discharge gave me alreaddy 0.1 volt more than the previuos charge session and its still slowly Climbing.
              better results ewpected with the next build.
              currently running on a 7 trans system single coil
              now building a 4 coiler for these batterys
              regards
              weasel
              • #22
                wheasel
                so you never charged a good 30-50 amp [car battery ] and discharged it
                if not how do you know if the ssg works .
                • #23
                  hello guy
                  on the first machine i had a couple 70AH batterys on the charge side
                  these did fine so yes i know it works
                  regards
                  weasel
                  • #24
                    hello folks
                    just wondering.
                    sorry jelloir for hyjacking your topic but its still about batterys
                    i came accros a strange thing today.
                    we emptyd the assid out of a battery and after this we had still a 8.95 volt on the battery..... how is this possible????
                    filled it up again with assid and its back to 12 volts
                    but just the fact to have a load when empty....????? it was holding this for a long time as well??????
                    regards
                    weasel
                    • #25
                      weasel
                      some batterys come dry and with a precharge
