Have built one of these bedini energises as per the manual I have used a 16 inch bike wheel with 12 cerimac magnets when I powered it up the wheel spins ok at 169rpm but one transistor is getting hotter than the others not having a scope I put a led across each coil and the transistor that is running hotter than the rest the led glows the brightest. The rest glow much less in varying degrees. Has any one idea of what is going on? Also when I first powered it up a couple of the neons flashed but not any more.
Ian
Ian
