hello my name is andre and I am a very noob in electronics but i am busting at the seems to try it out for myself so please forgive any naivete on my part.
i am trying to suply my house with this motor, the idea is running the motor that will run an alternator and the alternator will power the inverter.
the whells are made of aluminium 45cm diameter, the magnets are 7,5cm 5cm 2cm, pull force 10,1 kg , the circuit i used 2n3055 transistor, and i tried to use 470ohm resistor with 1w, and also with 0,5w ,
i also tried with mjl21194 transistor. the wire is AWG 20 and AWG 24 for trigger.
any thoughts why the motor does not work?
i made before one bedini motor with a bicycle wheel with ssg circuit one transistor and that one worked..
any help would be very nice
best regards
best regards
i miss that
Now I can hear the sound of the coil when I turn the variable resistance which is a good sign.
