Ben,
Usually the dry charge batteries are formed but it is recommended to add the acid and charge for two hrs.
If you look at your waveform it looks like a capacitor charging and discharging, You might try charging a super cap and watch the waveform, Lidmotor did real good with the old plates, you have done real good with your converted battery. I have converted batteries that did not work for some reason. It always depended on how bad the plates had been abused. Lead Acid batteries take some real abuse. I wanted a battery that you could take to zero and not hurt it. Crystal batteries fit the ticket, but most of them only developed 1 to 10 Ma for days. I was looking for a battery to drive the SG oscillators to light Led's. By converting the Car type battery it was possible to run hundreds of Led's for two to three days with small amount of sun charging which we have in Idaho. One of the chemicals I talked about in the Earth Light Forum was Epsom Salts gathering heat to generate power. Epsom Salts only works one time in a Lead Acid battery to clean the plates. In a crystal cell with Magnesium it works for heat. You must boil all the water out to use it. Hydrates hold the water locked up in the crystal, so what you really have is a way to use the conversion process to make and use water instead of acid. I was only using Milliamps in the circuits but that turns out to be Amp Hrs for days in a linear discharge curve with the led shining bright all the way down to zero volts. The new Mountain West discharger lets you name the cell and set the cell instead of useing a per-determined curves built into the software. Chuck has done all kind's of experiments running Crystal Batteries for days so he basically can tell if something is going to last. We will not be getting any sun soon here, so we are developing circuits that use very low light to charge. I have 4000 watts of solar panels. So we need batteries that can use small charge to give long hours of lighting. I will be videoing a car battery conversion to a crystal battery. The field is very important but most only consider this a hobby or a social network and will probably die with a Cell Phone in there Ass never knowing how to get energy out of anything. I have talked to you before about what I have been trying to do with the SG and other things. You know what it takes to do things and the cost associated with it. So I respect everything your doing Ben. But I think you understand what is being done here. Some do the Experiments along with you others just watch. Good work Ben hope to talk to you soon by phone, just Pm me and I will call you.
Lead Acid Dry Charge
