24A12 Industrial Battery Charger & Rejuvenator
This is a sticky topic.
  • 24A12 Industrial Battery Charger & Rejuvenator
    24A12
    Battery Charger
    24 Amps @ 12 Volts
    This industrial charger charges and restores the capacity of medium to large 12 Volt Lead-Acid batteries.
    This work horse can rapidly break down layers of sulfation and restore the battery's capacity.
    We recommend that you use the 12V Battery Load Box to cycle the batteries for full rejuvenation.
    This rapid restoration of capacity is what we call Rejuvenation. There is no other battery charging system in the world that can do this!
    • 12V model is available for use with 110VAC 60Hz or 240VAC 50Hz.
    • Unit weighs: 39 lbs, 2 oz.
    • Physical shipping box size is: 18 x 15 x 13
    • *1 Year Warranty
      GET YOUR OWN INDUSTRIAL ENERGENX 24A12: ENERGENX 24A12
    Admin
    Energy Science Forum
    I purchased one of this and im on the first week test but i have some questions.Did somebody experience it?Because i have some questions and maybe you can share info THANKS
      I've got one when they first came out,have used it on car batts, gulf cart batts and fork lift batterys. It will charge and discharge the batt automatically untill its not gaining capacity anymore. When hooked to a computer you can get a print out of the process. Nice unit.
      Mike Klimesh
        OK!So to connect to a computer that is very interest how did u connected,is posible that u need a loadbox?
          PaBloM, the original charger had the ability to cycle the batteries until the capacity no longer increased. This functionality is no longer available with the latest model, however you can now purchase the battery load box which comes with a meter with a serial interface and software that you can connect to a computer and display the discharge curves on the screen.
            RC-30A12-120 12V Industrial Rejuvenator Charger with Load Cycling feature
            So now is again the RC-30A12-120 12V Industrial Rejuvenator Charger with Load Cycling feature on sale that ok????
              The 30A12 with the automatic cycler is not available anymore.
              The rejuvenator we have is the 24A12: Tesla Chargers | Products
              and
              The 12V Battery Load Box: Tesla Chargers | Products
