I am not angry at your words or at you...... I can brute force energy all I want, thats not the point. oscillation, self excitation, resonance, tuned circuits, look at krons network analyser. you said it yourself permanent magnets have an internal resonance, its based upon their spins... thats why if you put a magnet in certain situations you can literally shake the magnetic structure out of ceramics and turn them into paper wieghts. same with neos you heat them above 175 and all the magnetic properties run away and its a paper weight too. the perendev motor needs a certain rpm to keep it running based upon its load, when the make/break cycle of the poles reaches its TUNED resonance to the load it self runs. they key to the testatika is the leyden jars. the galaxies are in resonance to each other, all the way down to the quantum state. even at zero degrees kelvin there is still chatter at the quantum state. we have an internal circadian rythm and we have a human frequency too. light is a particle AND a wave its measured in frequency. if the obvious clues given to us by nature cannot convince you then....... well enjoy the journey look forward to you posting your results.
By the time I make this replica you will already have the results because you will make it before me.
