I am ready to test a my own square style "GEET" system as soon as I come up with a simple circuit to pulse the fuel injector at a variable speed. P.P. has said it is not GEET since it is not round so there are no patent worries. My system is truly on demand using pulsed fuel injectors instead of the normal bubblers. A throttle body would be perfect to convert. Just move the one fuel injector to the fuel reformer. There are 4 ports on top for 4 injectors to mix fuels at different ratios on demand. There could be a start up fuel plus water - the running fuel. The fuels get vaporized instantly by exhaust heat in the top section. Then they go through the .032 gap around the double tapered square bar. The gap is maintained by pins on the 4 sides of the bar. There is a check valve and back flash protector on the out put side.
If any one knows of a simple fuel injector pulsing circuit then please let me know.
There is a picture of this device in my album called alternative energy.
you will still get good results from it however. you could use a simple 555 timer and mosfet to control the pulse width of the injector, a temperature probe in the exhaust could give you a reference of fuel air ratio quite well.
