Ok, so as of now, there are only about five questions left unanswered regarding the S1R9A9M9 wiring set up on the Briggs 18HP mower engine.
1.-- Why wasn't the same 400 Watt Inverter box used, as was on all the other many earlier car/tractor engine conversions? 110v AC with half wave or full wave rectification. Resistance in circuit is required for 10 amps. The spark plug electrolyte was about 10-22 ohms. There were MANY series diode voltage drops in the autos circuit schematic. The dual coils relay used per cylinder, in the cars, was about 1.2 ohms total of #21 gauge wire. Nathren said that it couldn't be used on mower engine ,as it came in at a frequency and would just bog down and shut off. If he tried to hook it up himself instead of the real technicians, then he didn't know what he was doing. The change over was then done with car 12v battery.
2.- Why did Nathren mention many times in his Forum that 100 volts and 10 amps was required to get an engine to start and run on water to hydrogen fuel gas. Did he, as ignorant, mean that he was talking about the 110v Inverter box? He also should have known that all the earlier engines were running on 6-7 amps per cylinder only ,as per the technicians. (garage oscilloscope and hand meters) Salt water Electrolyte at plug tips as about 10 ohms resistance.
3.-Why wasn't EGR applied on lawn mower engine for the 2 demonstrations of summer 2008. EGR with recirculated Nitrogen from exhaust smooth's out the earlier engines tested idling RPMS. Adjustable valves were added for control on the cars.
4.- If the increased high voltage from the Capacitor70 circuit provided that proper Plasma Path to allow heavy amps transfer through spark plug, then what was the Bare 5 turns copper #12 gauge coil be used for in that S1R triple coils assembly? Was that needed too? (crossover leakage inductance voltage, I tested, (90-200v) After being miffed ,I then decided that what might have happened, is this,--- After the 2008 demonstrations were over, Nathren clipped off the ground wire that was hooked to the extension cord. That left a stub wire in the black electrical tape with frayed wires you can see in the graph paper photograph. Blow it up to see. He then unwound the proper parallel 7 turns from the secondary side and rewound them directly over the bare copper wire as a 90 degree wind. Now there is no transformer effect as no steel core underneath 7 turns. Do you agree? Nathren was attempting to hide the pertinent data from the public. The final photo as on the graph paper is the converted one as shown to the public. What do you think?
5.- Why didn't Nathren run the mower engine on just battery power continuously, with the addition of alternator voltage. There are 2 halves of alternator with (2) AC outputs. Battery was used for starter motor and initial circuit start up circuit, so as engine was idling at lower RPM. Battery was completely removed for some reason. (Besides the high volts being on the battery as danger, no safety) The alternator is just wires with rectifier pulses. The extra wire on the starter terminal, going around back of engine, also ran the main circuit when the red positive battery cable clip touched it. Maybe the technicians wanted mower engine to also be self running, just like the V8 on engine stand in their shop running 24 hours-7days, with large generator attached, and water line. - Free electricity for shop.
