ULTRA CLARIFIER HEX BEAM
Ultra Clarifier "HEX- BEAM"
Ultra Clarifier "HEX- BEAM" NOTHING TREATS DIGITAL MEDIA BETTER
"Just when you thought it couldn't get any better!"
After many intensive years of research, Bedini has developed the new slim-line Ultra Clarifier "HEX- BEAM".
Now with SIX opposing electro magnetic beams, nearly twice the rotation speed, vibration dampening, improved timing processing and LED light processing indicator. You can now expect the very best treatment available from all your digital media.
The new "HEX- BEAM" extracts even more information than previously thought possible. If you are an owner of one of our other clarifier models, then you can expect to relive the experience again. We guarantee you will be listening to every disc you own as least one more time.
If you have a serious investment in your audio or video components, then you owe it to yourself to take a spin on the new HEX- BEAM Ultra Clarifier.
Once in a wile lighting strikes and the effects are breathtaking, a true experience of sight and sound that truly push our senses to the limit. What if you could actually reproduce this without losing all the subtleties and dynamics that digital media was intended to reproduce.
With hundreds of surface imperfections across the disk "error correction" can be thought of as "using the mathematically encoded backup copies of the data that was corrupted." Not only does the CD use redundant data, but it also mixes up the bits in a predetermined way so that a small flaw on the disc will affect fewer consecutive bits of the decoded signal during the playback. Because the Ultra Clarifier treats the polymer, less error correction is used and your listening experience is greatly enhanced.
New features include: Six Beams, LED Indicating Timing Cycle, Improved motor and Vibration Dampening.
GET ONE HERE: BEDINI HEX BEAM ULTRA CLARIFIER
