Self-Recharging Battery Supply of Carlos F. Benitez by Peter Lindemann, D.Sc.
  • Self-Recharging Battery Supply of Carlos F. Benitez by Peter Lindemann, D.Sc.
    NOTE: This machine was demonstrated at the 2018 Energy Science & Technology Conference (ESTC) but there was no formal presentation. It was only explained to attendees who were interested enough to ask Peter Lindemann questions about it back in the vendor/demo room. This machine is a very small powered demonstration, but proves the point and kept itself charged up all weekend while running a motor/generator. This EXACT circuit from 100 years ago is the foundation for several well-known circuits that have been taught by John Bedini and others over the years - you are being handed the origin of where much of it came from.
    Get your copy here: The Self-Recharging Battery Supply of Carlos F. Benitez by Peter Lindemann, D.Sc.http://emediapress.com/peterlindemann/benitez/
    Looks like this book is a must to understand the 'Tesla Switch' and the other mechanism that provide COP>1 in charging and Discharging (Powering a load) simultaneously.
    also, i read Rick spreading the garbage of discrediting John's chargers and that stating that it kills the batteries.. one must get enlightened to judge the truth..i guess this book will say it all!
      There is a 45 minute presentation but the pdf does have the supporting documents.
      Rick is a sociopath - not much else needs to be said about him.
        Hello Aaron and Peter,
        I viewed the Benetiz video over the long weekend and a big thanks is in order to Peter for putting together another informative and useful presentation. Enough historical information and an actual simple replication to flesh out exactly how this machine works. The fact that the end result is a high efficiency design configuration is an added bonus.
        Another intriguing build to add to my winter list.
        Yaro
          Hi Yaro,
          I posted this in Energetic Forum yesterday. All the rest of the component numbers should be in the drawings - this is for the diodes in response to questions:
          From Peter:
          RS gave the diode numbers in his presentation last year.
          The large diodes on the ground line are the MUR3060PT. Its a dual ultra-fast diode for switch-mode power supplies, rated at 30 amps per diode, 600v, and 50ns switching. They share a common cathode, so I only use one of the diodes in each device.
          The smaller single diode in the motor circuit can be any fast diode rated for the power, like the uf4007. The exact diode used in the demo is the MUR860G. Its a 10 amp, 600 volt ultrafast diode with 35ns switching.
            If the ZFM had just enough core material to give a significant spike on the discharge and had an isolated recovery winding, it could be run with this exact method. With the bipolar switching, not sure if it would work as simple as using a recovering winding.
