The bridging link between Gravity and Electromagnetism is the Physical Vacuum.
I have been pondering on the Unifying link between these forces of the Nature, and lately was astonished to see that Gravity and Electromagnetism bear the same relation as those of Electricity and Magnetism. hence they bear a Broken Symmetry (Asymmetry), this understanding will finally put to rest to the ambiguity to the term of Dark Matter and Dark Energy.
The Physical Vacuum as we know is a relative measure in terms of Magnitude, Direction and Motion, the understanding of Vacuum as a devoid of matter is only the sesnse to a physical VACUUM, whereas an 'Entity of devoid' (something like the Aether) will take a materialistic view to the nature of the Vacuum.
as an example, consider the Outer space Vacuum, its strength in a given point in the out space is a Inverse function of the gradient of Gravitational field strength of the other heavenly bodies in the vicinity to that point.
GRAVITY IS AN ATTRACTION FORCE OF INTERACTION
VACUUM IS A REPULSION FORCE OF INTERACTION.
